Hi there
i work for stone shop show room. i have to create frame for natural stone wich is transparant ( it looks like marble, but it is transparant)on the back side of the stone must be installed light (lighter)
have you any advice how to create transparant stone ( dont lose stone face) and also it must get light from back side. is it possible? Thanks a lot
transparant stone
- SketchUp: Sketchup 2020
Re: transparant stone
Use Material Template "Frosted Glass> Plexiglass" with attached settings and put your light emitting surface behind the texture, see example attached.
MUST BE RENDERED WITH EASY 09 OR 10 RENDER SETTING!
The color of the light is determined by the color of the light emitting surface - keep it white if you want only the color of the marble stone to be shown.
- Light-MarbleSlab.skp
- (40.98 KiB) Downloaded 362 times
- Light-MarbleSlab.jpg (46.67 KiB) Viewed 3643 times
Thank you very much Fletch
Users browsing this forum: No registered users and 38 guests
