T.V. Stand - Added Images
tuna57
Post by tuna57 » Sun Apr 16, 2017 8:05 pm
First version of an entertainment / t.v. stand I'm thinking about building. Decided to do a render. Arroway textures for the wood. HDR light tent by Rayman from the Kerky site. Wasn't in a hurry so ran it on Easy 9. Let render run while doing other work. 302 passes in 4 hours. Did minor adjustments in post pro, bumped up exposure a little and tweaked the temp just a bit.
Edit - In responce to suggestions made by alvydas I messed about with my t.v. stand some. In keeping with my intent to learn more about getting the most out of Twilight with out resorting to a bunch of work in an external photo editor, here's my second go......
Changed backdrop to a lighter color, switched my HDR light tent to a brighter one and rendered this image on easy 8 , 350 passes , 1 hour and 45 mins.
Image "2c" is straight out of Twilight, image "2c7000" I bumped the temp from 6500 to 7000
I think both the images are good, which is better ? Darned if I know. You be the judge. I'm figuring out this rendering business could make you crazy if your not careful ! :doh:
entertainment stand2_Scene 1 post.jpg (443.03 KiB) Viewed 4091 times
entertainment stand2c.jpg (468.71 KiB) Viewed 3975 times
entertainment stand2c7000.jpg (468.93 KiB) Viewed 3975 times
OS: Win10
SketchUp: 2016
Re: T.V. Stand
Post by Chris » Mon Apr 17, 2017 2:27 pm
tuna57
Re: T.V. Stand
Post by tuna57 » Mon Apr 17, 2017 4:09 pm
thank's Chris.
alvydas
Re: T.V. Stand
Post by alvydas » Mon Apr 17, 2017 4:55 pm
You can correct slightly the contrast and lightness :^: .
entertainment stand2_Scene 1 post.jpg (701.06 KiB) Viewed 4073 times
SketchUp: 2013-20
Re: T.V. Stand
Post by Fletch » Mon Apr 17, 2017 7:00 pm
very nice!
tuna57
Re: T.V. Stand
Post by tuna57 » Mon Apr 17, 2017 11:56 pm
alvydas, I understand the point your trying to make. I purposely didn't take the image into a photo editor. I was experimenting to see how good an image I could get just using Twilight's post pro tool. I ran the exposure up to 1.8 anything higher was blowing out the image to badly to fix with the temperature adjustment. After the exposure adjustment I adjusted the temperature 2 clicks to get my colors back where I wanted them. Although the adjustments you made to the image are very nice, to my eye the wood texture is a little oversaturated. Not a knock against what you did , just trying to point out everyones eye is a little different. Your comments are always appreciated.
Fletch, thanks
tomankubik
Re: T.V. Stand - Added Images
Post by tomankubik » Tue May 02, 2017 7:34 pm
:gj:
Walt
Post by Walt » Sun Jun 04, 2017 12:25 pm
Great work tuna57 I'm with you on the post pro in an external editor. I think Twilight has offered some really good post pro tools with in TWI if you can get good with them. If your on a Mac have you experimented with the color adjust tool in Preview?
Mike1158
OS: W10
SketchUp: V19
Post by Mike1158 » Tue Jun 06, 2017 9:27 am
That is brilliant.
Users browsing this forum: No registered users and 51 guests
