animation with only sun moving.
hello,
I test rendering with only sun as light,
the purpose is to show the path of the shadow on wall......
So I procede like that, but this procedure seems to be wrong..
first scene : shadow on, shadow from sun, time begin 07:50
final scene : shadow on, shadow from sun, time ending 20:00...
I use 02b low aa2 as I have inox metal as indicate to me in an other post.
result : bing wrong specular color.... there is only 1 second between this scene....
the link to view fast rendering video :
https://drive.google.com/open?id=0B6hI4 ... 211R2hINWM
So....what is the good process , or what is my error ?
Thank you all.
Thank you all.
Re: animation with only sun moving.
I've just testing rendering with
No sun environment (deactived)....same error,
No shadow from sun.....same error...
Strange effect......!!!!
Render with Animation render settings.
Render Settings>Express>4)Animation
Set floor to "Flat" material template.
Try in Environment to enable "Corrected Shadows" check box. Be sure Sun Enabled And Sun Shadow is enabled.
It seems it is the solution....
AS the video is render, I post it.
in this time I 'm looking one machine with more Core.......
- SketchUp: Make 2017
Hello!
It's hard to tell from the video alone, but my guess is that the render method itself is to blame. I'd suggest using an unbiased render, like Interior or Exterior, which should give you better results. Here's a quick test using the Interior render at 25 passes: Hope it helps!
//Andrew
//Andrew
Andrew F
Hello, thank you Andrew..;
As unbiased render seems to me very long... for an anim of 600 frame...
But for fix shooting it's a solution I'll experiment.
Nota : the render are doing in client office, so I'v very limited time for render the view.
Do not use any light emitting materials in animations.
Ok all is fine in this preview.
I have corrected timin in animation under model information. there is trouble if I mention more time as the interval between scene..so some test were useful...
I'll work on specifique view for test, before start an all dim render.
https://drive.google.com/open?id=0B6hI4 ... zFUQ1JHemc
Oh another trouble......
same project,
other plan view
red stone wall : materials : stone polished...
with easy 07 : all seems good....
with animation 03 Hight +: exactly same object, just change the render mode.
What is the trouble???
same project,
other plan view
So I test with another model from me,
I think the Barcelona Pavillon, was not modeling very well.....I had to cleaning and recmposing it.....
Waste of time......
Waste of time......
Users browsing this forum: Ahrefs [Bot] and 58 guests
