Is AMD Ryzen 7 2700x good for new machine setup for Twilight rendering
kay P
Post by kay P » Sat Dec 01, 2018 3:15 pm
Hi,
Newbie query pls. Need your advise on buying new PC for Sketchup+Twilight rendering .
I had finalized AMD Ryzen 7 2700x (mainly to reduce cost as a hobbyist) .But someone told that this CPU is not upto mark for Sketchup ? My Original choice was or Intel Corei7 8700k CPU but changed specs as per budget.
Please guide if it is good choice. I shall be doing Interior/Architectural scenes stills ( medium /large size) for concepts .
Thanks in advance.
Cheers!
Kay
Re: Is AMD Ryzen 7 2700x good for new machine setup for Twilight rendering
Post by Fletch » Sat Dec 01, 2018 11:01 pm
Intel Core i7-8700K vs AMD Ryzen 7 2700X
Userbenchmark
Effective CPU Speed: 107% vs 99.9%
Intel Core i7-8700K - 15th / 1139
AMD Ryzen 7 2700X - 21st / 1139
Seems pretty nice from this benchmark. 8 cores/16 threads should be great - if you have proper cooling for your CPU.
Check out our benchmark scene when you get your new rig. Don't forget to run a render using your current rig for comparison's sake.
Subject: V2 How Fast Are You - Official Twilight Scene - Bauhaus Lamp
kay P
Post by kay P » Sun Dec 02, 2018 7:37 am
Thanks Fletch for your prompt response!
I was worried as I saw this post in SketchUp forum as I was sitting in my PC guy shop getting it assembled... and told him to stop the build till Monday so that I may get some advice .
Here is the post (ref last comment ).
https://forums.sketchup.com/t/amd-ryzen ... r-su/42482
Since I am a total noob in SketchUp and Twilight , I thought it shall be better to shell out his money after seeking guidance from the helpful community here.
Regards.
Kay.
kay P
Post by kay P » Mon Dec 03, 2018 4:18 am
Hi ,
Is there anyone out there who is having similar CPU .Your feedback shall be very helpful.
Regards.
Kay.
Post by Fletch » Tue Dec 04, 2018 3:54 pm
That post was from more than 90 days ago, and I have no experience with Ryzen.
No one has posted any problems here about Ryzen with Twilight.
Hope you can find your answers quickly.
As far as Twilight and Ryzen, I don't know why there would be any problems... the more cores/threads the better in most cases. The only time you will see performance degredation with multiple cores/threads is if you are rendering a very small image, then the cores seem to get mixed up somehow... but on any image at 1920px wide or greater the more cores the better.
Post by Fletch » Tue Dec 04, 2018 4:19 pm
Important- I would be sure to get an NVIDIA video card -
Be sure to verify your NVIDIA card is Cuda compatible and running a driver of version 390 or greater. This gives you opportunity to upgrade to a new upcoming FastForward plugin for Twilight Pro. Allowing you to render up to 3x faster (or more).
kay P
Post by kay P » Wed Dec 05, 2018 4:21 am
Fletch wrote: Tue Dec 04, 2018 4:19 pm Important- I would be sure to get an NVIDIA video card -
Thanks for your response. I finally got my pc now with the Ryzen 7 CPU,16 GB ram with Quadro P620 graphics card (CUDA Cores 512,peak Single Precision FP32 Performance 1.386 TFLOPS, GPU Memory 2 GB GDDR5).
Shall update on the test results soon.
Cheers!
kay P
Post by kay P » Wed Dec 05, 2018 9:15 am
Fletch wrote: Sat Dec 01, 2018 11:01 pm Check out our benchmark scene when you get your new rig. Don't forget to run a render using your current rig for comparison's sake.
Posted the results there For Bauhaus Lamp . :^:
Is it possible to get a more detailed model (twilight rendering ready) of Interiors to test the speed in relatable scenarios ?
Cheers !
Post by Fletch » Wed Dec 05, 2018 7:23 pm
There are several scenes for free in the Freebies section of the forum.
Try rendering the bedroom scene, and
Subject: Gemstone Jewel Diamond Wine Glass and Spoon by Massimo.
The splitting beam with prism is a great torture test for a render beast like you have. :^:
kay P
Post by kay P » Thu Dec 06, 2018 2:16 am
Will try these out .
We should have a page comparing one of these models ..just like Bauhaus lamp one.
Thanks!
Users browsing this forum: No registered users and 48 guests
