Got Milk? SSS
- SketchUp: 15
Got Milk? SSS
The milk is a custom material using the deep material editor. Its close but not perfect but I spent way too many
hours tweaking and re-rendering so for now I will post the result of my efforts and put this one to bed.
Lighting consists of 2 IES spotlights and an HDRI
Rendered with Easy 10 Interior +, 2hours, 70 iterations on an i7 6700. Minor contrast adjustment in Photoshop.
- Milk_01c_SSS.jpg (827.72 KiB) Viewed 13508 times
Re: Got Milk? SSS
Milk & cookies yum...... Only thing I see wrong is you should have a "Crazy Straw" in the glass.
- SketchUp: Make 2017
Re: Got Milk? SSS
I want some now
Great render
Only thing is, the milk looks a bit too clear towards the bottom.. Maybe it's been staying out in the glass a bit too long
Great render
Andrew F
Re: Got Milk? SSS
People, it's a low fat milk!
- SketchUp: 2018
- SketchUp: 15
Re: Got Milk? SSS
Right on Posodrac, low fat skim milk is what it does look like.
Attached is another render using the stock Twilight Subsurface Scattering Milk, same lighting, but it leaves a lot to be desired.
Thank-you!
Thank-you!
- Milk_StockTW.jpg (887.19 KiB) Viewed 13481 times
Re: Got Milk? SSS
Hi RangerRick - did you try this milk material already? It should be in your stock Twilight Materials. Go to "import library" in the Twilight Materials dialog.
CORRECTION - JUST saw your last post.
Yes, it doesn't look right in your rendering.
- milk-mat.JPG (58.58 KiB) Viewed 13480 times
Re: Got Milk? SSS
What kind of glass are you using? The laterals look odd to me!
Do you got the geometry right? Including faces?
Re: Got Milk? SSS
Wow...this is awesome. You really brought the liquid to life, which isn't easy.
Users browsing this forum: Bing [Bot] and 85 guests
