Pipe Wrench
- SketchUp: 15
Pipe Wrench
A lot of my renderings have a connection to a memory or are from a period in my life.
I have held one of these pipewrenches and had threaded tens of thousands of fittings
in a former life. I used Thom Thom's Sub-D plugin to model the aluminum main body of
the pipewrench, pleased with the result.
- Rigid_Pipewrench_TW.jpg (766.89 KiB) Viewed 12272 times
- Rigid_Pipewrench_SU.jpg (723.79 KiB) Viewed 12272 times
Re: Pipe Wrench
Marvelos render, you make it look easy.
- SketchUp: Make 2017
Re: Pipe Wrench
Once again, great results!
Oh and is that default SketchUp 3D text I see there on the pipe bends
shakes head in disapproval
Andrew F
Re: Pipe Wrench
I'm fascinated with the quad modeling of the pipes - care to share workflow?
- SketchUp: 15
Re: Pipe Wrench
Thanks guys. Fletch, the elbows are just a SketchUp extrusion of a circle along a path with the Follow Me tool.
Andrew, you got me there
Re: Pipe Wrench
WOW!!!
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 5 guests
