white kyoto style
Re: white kyoto style
yes I think you're right. This might be the message in Kanji!
Is the bump map inverted?
It does not seem to be as other viewing angles work well. Just the angle of view in that one imho.
these are the files I used and the settings.
(I can't remeber where I found the textures)
- Unbenannt-3.jpg (84.7 KiB) Viewed 8413 times
- BrickRound0030_7_S.jpg (440.41 KiB) Viewed 8413 times
- BrickRound0030_7_S-bump.jpg (418 KiB) Viewed 8413 times
- SketchUp: Make 2017
I really like the results, even tho it's not really my style. And the blurred backdrop for the exterior was a good choice, it keeps you focused on the interior part
The stone wall does indeed look like it has an inverted bumpmap.. especially in the first render
I fully support that
Andrew F
The bump map looks more for a reflective map to me.
From what I can tell it just seems like a monochrome version of the texture, with the contrast increased.
Andrew F
Sort of got to wondering about the bump map for the rock texture also.... Suspect one of the problems is the tonal range across the whole texture image is pretty similar. So.... thought I'd mess with it some. No expert at this but have made a fair amount of bump maps in Gimp that usually seem to work o.k.
Took the texture image into Affinity and selected all the grout / mortar lines and darkened them up a bit.Then took that into Gimp and did my usual stuff to make a bump map. Think it works pretty good. Posting the altered bump map and a quickie render of it. Had the bump set at 1.0 for the render.
Give it a go and see if it works for you .
- BrickRound0030_7_S copy3_B.png (524.82 KiB) Viewed 8379 times
- rock_new bump_1.0.jpg (638.2 KiB) Viewed 8379 times
Good job on the map!
Users browsing this forum: Ahrefs [Bot] and 16 guests
