Two levels, internal footprint 11' X 11'.
A small student flat. Two levels but everything about as small as it can be made, the wood block wall is intended to be made of a linoleum type of wall covering but fire resistant. The bathroom door is a slider. Not come up with a 100% method for locking or even opening/closing but I will.
- 2 9 20p 2h 7m Ir 0 a R.jpg (149.51 KiB) Viewed 8980 times
- SketchUp: Make 2017
Re: Two levels, internal footprint 11' X 11'.
Pretty good!
Just wondering, where is the light coming from? Seems like the whole ceiling is emissive to me, that makes for some rather uninviting lightning imo
Andrew F
Nice image, Mike, explains everything to client perfectly.
Do you work at a company that specializes in tiny apartments?
RTD is right, the lighting could be more attractive, but it does work to light up the space quickly and get an idea across.
Thanks folks, still building the model and populating. The odd light effect is from a light box for offset overhead views. I just wanted to check mats and lighting levels. I must get into advanced mat settings.
intersting start and concept. Hope to see more.
Ta mate, more..
- Lower level.
- 4 9 25p 1h 35m Ir 0 a R 2.jpg (126.66 KiB) Viewed 8942 times
Thank you. The two tone window is an experiment to mimic the potential use of adhesive sheeting to reduce/remove the need for blinds/curtains but it does not work for me, blinds next.
Re: Two levels, internal footprint 11' X 11'. New image.
Altered state.
- Adjusted again.
- 6 9 25p 1h 55 Ir 0 a R.jpg (180.4 KiB) Viewed 8912 times
