Modern hotrod?
Modern hotrod?
Just a test of the body surfaces and shutlines.
- Surface test.
- 5 9 12p 19m Ir 0 a R.jpg (99.52 KiB) Viewed 8094 times
Re: Modern hotrod?
Thank you.
I'm thinking of doing a scheme typical of modern hot hatchbacks, white and black/de chromed. When I get things like bonnet shut lines and vents hopefully ( ).
Wrong picture.
Engine vents and bumper 1.
To add door handles or not, tricky.
- Right picture.
- Vent Test 5 20p 22m Ir 0 a R.jpg (109.17 KiB) Viewed 8067 times
Re: Modern hotrod?
Night HDRI.
- HDRI
- 6 9 50p 1h Ir 0 a R.jpg (161.62 KiB) Viewed 8061 times
- SketchUp: Make 2017
Re: Modern hotrod?
Neat!
The lighting seems very wrong in the last one tho.. And it'sparked on the sidewalk
Andrew F
Re: Modern hotrod?
Thanks, the last was to test a theory which proves hdri are fine in some instances but harder to master and less use than I supposed.
Re: Modern hotrod?
Proper night test #1.
- #1
- Night Test 1 Ir 0 a R.jpg (305.43 KiB) Viewed 8047 times
Re: Modern hotrod?
Next.
Suggestions.
Suggestions.
- Night Test 3 8 7p 3h 15m Ir a R.jpg (181.37 KiB) Viewed 8038 times
Studio render.
Just having a go.
- Studio Test 1 Ir a R.jpg (150.14 KiB) Viewed 8020 times
- Studio Test 1 Ir 0 a R.jpg (232.02 KiB) Viewed 8020 times
Users browsing this forum: Bing [Bot] and 120 guests
