Gold Powder Coated Material
I'm not very good with twilight hobby but was wondering if anyone had some advice on a not too difficult way to get something similar to the photos I have attached. Thank you!
- image.png (1002.11 KiB) Viewed 8534 times
- Screen Shot 2019-11-23 at 7.13.35 PM.png (686.63 KiB) Viewed 8534 times
Re: Gold Powder Coated Material
Blurry Metal - 50 shininess - gold color in reflection and color of stand as light grey
download files below - load the hdr image into the spherical sky for same lighting.
lighting in your scene will be key - the metal needs something to reflect. Don't just float it in an empty sky it will look bad.
- GoldPowderCoat-metal-stand.jpg (188.79 KiB) Viewed 8524 times
- GoldPowderCoat-metal-stand-scenefiles.zip
- hdr image for lighting of provided scene
- (507.53 KiB) Downloaded 422 times
- GoldPowderCoat-metal-stand.skp
- (253.6 KiB) Downloaded 426 times
thank you so much!!!!
Fletch,
I'm rendering a bathroom vanity and I need the background to be white. Any suggestions? I have attached photos of the views I need.
Thanks again for all your help!
Warner
Warner
- MilesCollectionVanity_36Inch_Base_Front__02559.1536873548.1280.1280.png (4.04 MiB) Viewed 8506 times
- MilesCollectionVanity_36Inch_Base_Side__84734.1536873564.1280.1280.png (4.36 MiB) Viewed 8506 times
and if you have any tips for glass I would most appreciate it!
Render the object with as good of lighting as you can get with proper nice reflections, then render the Alpha Mask and put the object on a pure white background using the alpha mask. (link to tutorial for this below) Or at least build your white studio for the object only as big as necessary, and light the image with good lighting, such as HDR or a Product Light Studio. See link to tutorial below.
Your renderings will only be as good as your model.
Get Fredo Roundcorner plugin and bevel all the edges of your furniture in a second, or use Twilight Pro Bevel modifier.
Build furniture glass like this:
Subject: Model: Glass Table Top with Green Edge
Subject: Jewelry and Product Shots - the Right Light
Subject: How to use HDR image or HDRI image
Subject: Studio for product shots
thank you for your help!
Any suggestion on the best way to render this black metal? Thank you!
- 543352EE-D12B-4193-B668-791E763FD969.jpeg (1.07 MiB) Viewed 8441 times
Need something like that?
- TWILIGHT SCENE2 2.skp
- (2.46 MiB) Downloaded 413 times
- 1.png (257.37 KiB) Viewed 8429 times
- Rainer-Blackened-Steel.jpg (220.43 KiB) Viewed 8428 times
Create a good texture map (like alvydas provides above ) that you can apply to your model with that look, and apply a good template that gives the finish you like... like maybe try Paint>Satin?
maybe his is too black, you can lighten it with the SketchUp material editor, or lighten the texture in any decent texture editor like gimp or photoshop.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 7 guests
