What would you do with this little scene?
Here's an old test scene I stumbled across.
I have it credited to "Pibuz" but I'm not sure where it originated. If you know, please let me know.
I'm sharing the scene here with a challenge:
What would you change in this scene to improve the photo-realism in Twilight Render with this scene?
Please render and post your response below...
- scena studio legno-TWL_Scene 2.jpg (982.11 KiB) Viewed 13509 times
Re: What would you do with this little scene?
HDRI, glass in the patio doors and a slight view change.
- scena studio legno-TWL 2_Scene 4 2 45p 2h 8m Ir 0 a R.jpg (267.61 KiB) Viewed 13429 times
very nice, Mike, the exterior looks very natural.
Fanks folks, orienting the background was a bit of a mare.
OK, can anyone tell me how to attach HDRI files please?
Added, I am guessing the 4' tall patio doors was not worth mentioning but thought I would. Sort of thing I occasionally do.
What I meant about the patio doors.
- scena studio legno-TWL 2_Scene 4 3 45p 2h 13m Ir 0 a R.jpg (272.9 KiB) Viewed 13398 times
- SketchUp: Make 2017
Looks good Mike, I like the sunlight on the wall in your version better tbh . Only thing I'd say is the chair outside, you should model some ground under it or add a shadow in post because rn it seems to be floating in the air
(Also just noticed but what's with the green square in the top right... a rendering glitch?)
Andrew F
Thanks, I'll check the thing hanging in the air that I completely missed so thanks for the pointer. The chair does not have to be there really but I tried the hdri on the off chance I could get it close enough. There is no 'ground' there as you pointed out.
Floating cure?
An skp grass model at the base pf each leg.
- scena studio legno-TWL 2_Scene 4 4 70p 3h 29m Ir 0 a R.jpg (272.55 KiB) Viewed 13357 times
Sketchup export.
- Sketchup export.jpg (257.88 KiB) Viewed 13356 times
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 41 guests
