The grass and wall are hdri which is why the shadow was missing from the bench. I mad a box with one face removed and made the interior faces for the hdri. I will post an image when rendering a current render is complete.
I have tried adding the hdri file but it is again being rejected. I'll think of something
hdri zip is on my one drive. https://onedrive.live.com/?id=3B9C5A96A ... 96AA152674
What would you do with this little scene?
Re: What would you do with this little scene?
- hdri 'box'
- scena studio legno-TWL 3.jpg (68.59 KiB) Viewed 9251 times
I have had to rethink the whole scene again for reasons of practicality. I thought about what I would wabt from the space if it were mine and came up with.
A much nicer seat than a tall stool which seems an odd place to read on.
Protection from direct light to make it easier to read
Something to listen to music from.
A proper deck rather than concrete.
I think I have learned quite a bit from looking at this scene and going through changes piece by piece, it seems so anyway.
- scena studio legno-TWL 2_Scene 4 8 45p 2h 49m Ir 0 a R.jpg (312.25 KiB) Viewed 9235 times
- SketchUp: Make 2017
Well, took a bit longer than I wanted to but here's my take on this. I ended up re-modelling most of the scene because that was easier than fixing the existing geometry, but didn't really change much as far as the layout goes.
The main changes are:
- Expanded the view and added an HDR background for the outside, added a proper window.
- Changed most of the materials for a better match, mainly the wall, floor and trim textures.
- Added a carpet, mirror, wall outlet. Replaced the items on the shelves and the plant with more realistic versions, as well as replacing the magazines with books.
- Some other minor changes like lighting and small adjustments for the existing models (paintings, chair)
Only post-pro is some light color grading, adding a bit of bloom and denoising the render (the TWR Denoiser doesn't work for some reason )
Oh, I also figured I should try make some videos on how I go about making my renders, and just give a more detailed explanation than what I can do here. So this scene would be my first video and hopefully I would have that up by the end of the week or so. If this works out I might even make more of them in the future
[Edit] Video will be delayed for a bit, was hoping to get it done earlier but had issues with my editing software. Going away for a while now so it won't be out for a few more weeks
Last edited by RTD Laboratories on Fri Feb 21, 2020 4:34 am, edited 1 time in total.
Andrew F
Nice one Andrew, looking forward to the video.
Hey Andrew,
The denoise artifacts are strong... hope you will render more clearly and I'm very much looking forward to your video
Thanks! Yeah the quality not great, I was in a bit of a rush to get it up and had to re-render it when I realized I had an object without a material applied. Letting it render again now tho
Andrew F
Users browsing this forum: Bing [Bot] and 28 guests
