Student apartment
Student apartment
A small apartment with two levels. 16' X 20'.
- Upper floor.
- 1 4 9 25p 2h 19m A Ir 0 a R.jpg (252.57 KiB) Viewed 8735 times
Re: Student apartment
very good
hallway light looks "blown out" like it's too bright - my guess is that light powers are too strong, and should be lowered, then the overall lighting boosted with Exposure setting in the Render Dialog "Post Process".
I've recommended in the past that whites be set to 90% grey, but here's an idea...
Try setting all white surfaces (like white walls for instance) to 70 percent grey, and your darkest surface to 10 percent grey. Adjust all other colors to be relative to those extremes along that spectrum.
Then, when you light the space, the surfaces have a lot more room to "lighten" from the light. Or darken from shadows.
Run practice renderings without any furniture in the space to get faster tests as you adjust lights.
Adjust rendered image with exposure/tone map settings.
This should theoretically also reduce errors in calculations and increase render speed, shorten render times.
Thanks Fletch, I will get it right.
Good start Mike. Look forward to more. Also great advice from Fletch.
Ta mate, I have had huge issues logging on here since my last post. Password not accepted, capcha that's illegible, weird.
- 1st Floor
- 1 8 9 20p 1h 03m A Ir 0 a R.jpg (289.95 KiB) Viewed 8677 times
- Ground Floor
- 1 7 9 15p 1h 29m A Ir 0 a R.jpg (266.19 KiB) Viewed 8677 times
"Try setting all white surfaces (like white walls for instance) to 70 percent grey, and your darkest surface to 10 percent grey. Adjust all other colors to be relative to those extremes along that spectrum".
I must have missed how to do this, do you have a link please?
How to set white to 70% gray in SketchUp
- white-70.gif (236.15 KiB) Viewed 8639 times
NOW I remember, thanks Fletch, my grey cells might need a recharge tho'.
Users browsing this forum: Ahrefs [Bot], Majestic-12 [Bot] and 24 guests
