glass magnifying
glass magnifying
Help, could someone explain why the bookshelves beyond are magnifying in the glass. Thanks to all
Re: glass magnifying
Is your glass material using the Architectural Glass template? If not, you should switch it to that. It doesn't have any refraction in it and will prevent distortion from glass thickness.
- arch-glass-common.jpg (52.2 KiB) Viewed 11687 times
Thank you Fletch for quick response. I will check the template on Monday. Will let you know the result.
Ron
Ron
Sorry, thank you also Chris!
As a pro user, if you apply the basic Grey or Blue glass from SketchUp, these should be auto-magically applied for you and render correctly "out of the box" this will not be the case if you "tweak" the materials or rename them or apply something different. In those cases, you will simply need to apply Architectural Glass>Common and it should look great.
- Untitled-1.png (29.51 KiB) Viewed 11677 times
Thank you! Thank you! The architectural glass was the trick.
Users browsing this forum: No registered users and 45 guests
