Error message
Error message
Hopeing someone can help me navigate this error message whilst trying to run twilight, there is no problem installing the extension however it comes up with this error message when sketch up opens up & there our no twilight tools in the "view". any help would be much appreciated. see error message below.
Error Loading File /Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2/twilight2_loader.rb
Error: #<LoadError: dlopen(/Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2/27/TwilightLibV2.bundle, 9): no suitable image found. Did find:
/Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2/27/TwilightLibV2.bundle: mach-o, but wrong architecture
/Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2/27/TwilightLibV2.bundle: mach-o, but wrong architecture - /Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2/27/TwilightLibV2.bundle>
/Volumes/SketchUp 2022/SketchUp 2022/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.7.1/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in `require'
/Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2/init_twilight.rb:28:in `<module:TwilightLoader>'
/Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2/init_twilight.rb:5:in `<top (required)>'
/Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2/twilight2_loader.rb:2:in `<top (required)>'
/Volumes/SketchUp 2022/SketchUp 2022/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require'
/Volumes/SketchUp 2022/SketchUp 2022/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load'
/Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2.rb:15:in `register_extension'
/Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2.rb:15:in `<module:TwilightLoader>'
/Users/chrischeetham/Library/Application Support/SketchUp 2022/SketchUp/Plugins/twilight2.rb:4:in `<top (required)>'
Re: Error message
please provide your operating system information, thank you
Re: Error message
If you are using macOS with an M1 processor, you will need to run SketchUp 2022 using Rosetta.
https://www.twilightrender.com/phpBB3/v ... hp?t=12395
Re: Error message
thanks for the reply guys, I am on a Mac, newest version. I will try rosetta thanks guys
Re: Error message
Also my business partner has the same Mac, bought at the same time and we managed to download twilight without any problems on that one, any other thoughts? many thanks
Re: Error message
Are you using the same version of SketchUp? Prior to SketchUp 2022, SketchUp automatically ran in "compatibility / legacy" mode. Starting with SU 2022, they release an "M1 native" version. Since Twilight Render doesn't run natively on M1, that is why it won't work unless SketchUp is launched with Rosetta (to put it into "compatibility" mode). So maybe the SketchUp versions are different?
Re: Error message
Do you mean "install" and "run" or do you really mean "download"? Sorry for confusion.CHRCHEETHAM1993 wrote: ↑Mon Nov 28, 2022 5:38 am we managed to download twilight without any problems on that one,
Re: Error message
sorry, to clarify, yes we installed & ran the extension on my business partners Mac, it works fine, however it doesn't on mine, I have tried the rosetta route as well, still having the same error message.
Re: Error message
Ok, so that's very confusing indeed.CHRCHEETHAM1993 wrote: ↑Tue Nov 29, 2022 8:03 pm sorry, to clarify, yes we installed & ran the extension on my business partners Mac, it works fine, however it doesn't on mine, I have tried the rosetta route as well, still having the same error message.
I would try to do a clean and complete removal of everything Twilight, then try restart the machine then re-install Twilight.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 30 guests
