Hi Guys,
Help Please.
I am trying to acheive a dark shade mirror without any success
Can someone pls point me a direction on how can I acheive this
I've attached both the SU and TWL view for clearer indication about what I meant.
Pls don't mind the design and render , it for test run only
Thanks in advance
Thanks and Best Rgds
Tom
Dark shade mirror-help please
- rm2-aa-1.jpg (206.25 KiB) Viewed 5582 times
- low1-6-50.jpg (236.04 KiB) Viewed 5582 times
Thanks n Rgds
Tom
Confucius
Tom
Confucius
Re: Dark shade mirror-help please
Not sure I understand exactly what you're looking for, but for more advanced materials, I suggest that you use the Material Editor in Kerkythea...
Perhaps you can use one of the materials from the Dark mirror glass material library...
I just made a quick test, where I used the Dark mirrir glass #15, I assume that this is similar to what you're looking for - or...?
- Dark-mirror-TWR.jpg (406.65 KiB) Viewed 5557 times
Kim Frederik
Twilight Render Support
Kim Frederik
Using the Mirror Template in Twilight this must be possible.
If you read this thread about how to use the Water Template and apply what you learn to the Mirror Template, I'm sure you will find the answer.
You might try Applying the "Realistic Glass" template, set Opacity to 100 (opaque) and change the color of the glass to something a little darker.
Increasing Shininess and IOR will change the reflective property of the glass and give it a mirror-like appearance.
try the Architectural Glass>Mirror Glass material template:
- darkmirror.jpg (171.48 KiB) Viewed 5510 times
- darkmirror2.jpg (179.26 KiB) Viewed 5507 times
Thanks Fred, I hv not try linking Kerky material to Twl think its high time I do that
Thanks Fletch, that is what I needed
Attached render of the dark shade mirror for viewing
Thanks again for the help and Merry Christmas and a Happy New Year to all
Rgds
Tom
Rgds
Tom
- mid-22m56s.jpg (56.61 KiB) Viewed 5469 times
- mid-27m52s.jpg (57.03 KiB) Viewed 5469 times
Thanks n Rgds
Tom
Confucius
Tom
Confucius
Users browsing this forum: No registered users and 41 guests
