Re: How Fast Are You - Official Twilight Scene - Bauhaus Lam
Just got a new machine, here's what I got;
- Lamp 21s.png (216.43 KiB) Viewed 16961 times
- SketchUp: 2018
CPUs Socket 2011
Intel® Core™ i7-3930K
Core™ i7-3930K (6x 3200 MHz)
Moederborden Socket 2011
EVGA X79 SLI
X79 SLI (Intel® X79 Express)
Geheugen DDR3-2133
2x Kingston HyperX 8 GB DDR3-2133 Kit
8 GB DDR3-2133 Kit (8192 MB)
Grafische kaarten NVIDIA PCIe
EVGA GeForce GTX 680
GeForce GTX 680 (NVIDIA GeForce GTX
680)
CPUs Koelers
Noctua NH-D14 SE2011
NH-D14 SE2011 (2011)
EVGA X79 SLI
Geheugen DDR3-2133
680)
CPUs Koelers
- Vastleggen in volledig scherm 10-11-2013 144911.jpg (142.89 KiB) Viewed 16860 times
Here's my results from my new 2.4Ghz i5 Retina Macbook Pro 13".
I can definitely see an advantage in upgrading a computer regularly, my last laptop was a top of the line 2010 2.66Ghz i7 Macbook Pro. This new one is a 2.4 i5 (the base spec) and yet it's 30% quicker rendering the scene!!
- Screen Shot 2013-11-10 at 18.00.41.png (429.4 KiB) Viewed 16607 times
hmm.... there is something wrong with that i7 machine. The 2.66Ghz i7 should have a time around 31-34 seconds (see similar machine specs in other posts in this thread)JakeMM wrote:... my last laptop was ... 2.66Ghz i7 ...new one is a 2.4Ghz i5 ... and yet it's 30% quicker rendering the scene!!
I think the laptop version might differ from the desktop one and possibly be run at a lower power? I had the whole logic board of the laptop replaced a month or so before doing those tests and the laptop has been performing flawlessly. Heat did have some bearing on the time (when started from cold, the laptop achieved the times posted, however when continuously run through the test for 4 or 5 times, it ended up adding a couple of extra seconds).
Also the Geekbench scores for both the laptops show the i7 2.66 with a score of 4000 and my current i5 2.4 with a score of 5300. This shows the new laptop is a more powerful machine and as the i5 2.4 completed the Bauhaus Lamp in 41 seconds, it shows the i7 2.66 in my laptop is probably right as it's not less than the desktop time of 31-34 seconds.
We have seen i5 machines beat i7 machines on this very test.
It turned out that the cooling for the i7 was insufficient resulting in engaging the i7's safety throttle. It simply continues rendering and appears to be rendering properly but it is not. There is no obvious notification given by the system when the i7 throttles down. When an after-market cooler was installed into the i7 machine, the proper speed was achieved. This problem is bigger with laptops which do not have a lot of room for proper cooling, and a cooling pad is required in some cases (like with the high-powered i7s which are notorious for running hot.)
Hi. Just got a new machine, here's the result.
Specs:
Lenovo E531 with Intel Core i7-3632QM Ivy Bridge 2.2Ghz, 8GB DDR3, GeForce FX 740M 2GB and Intel HD Graphics 4000 2GB.
Specs:
- twilight test1.jpg (171.27 KiB) Viewed 16497 times
Hi to all, I'm a architect transitioning from 3DMax, and learning the ropes in TR, fantastic program and support!, here is my speed test (hope I have the right format).
Octavio
Octavio
- LampTest.jpg (169.74 KiB) Viewed 16184 times
, Octavio, let us know how we can help. It is a good machine.
- SketchUp: SU 2017
After a lot of , including three dead machines , and two HDD crashes , I FINALLY got my render machine!
AMD FX-8350 8-core @4.oo GHz
16 GB RAM
GeForce GTX760 (2GB)
So after a few kerfluffles with trying to get back into my account, change the password, update my email addy and so forth, I'm finally back. And, I decided to finally run the test scene.
So, here's my results: Ran a second test @ full 64 threads, just because I could The results were interesting.
Twilight finished in 11 seconds, but then sat there saying antialiasing 99% for another 41 seconds while slowly winding down from all those threads.
So in the end, it took 20 seconds longer, because of all the threads.
Anyway, the upshot is, I have a machine I'm proud of, and proud to post speed test results.
Edited because I forgot to list processor speed!
Cathryn
16 GB RAM
Cathryn
Cathryn Shaw
