first attempt at exterior
I'm trying to learn to use Twighlight..if anyone could pitch any ideas to clean this render up that would be great
- 66.jpg (512.59 KiB) Viewed 9110 times
Re: first attempt at exterior
What hdri are you using? You need a higher definition type whatever hdri. More scene setting and some bump to start things off.
In a first glance it needs some exterior lighting to pump up the properties of materials you using. They look flat to me. There are some light componentes ready to use shared in this forum, at Resources, you can use. Can't tell if the background is a HDR image or how you lighted the scene. The light look too difuse, almost can't find shadows.
Personally, I like the look you are going for but the background texture might be the darkening issue you are having with the rest of the rendering. Also, some of your textures seem a little large for the faces that you put them on. I know that there is a great free texture site but, currently do not remember the website title. If I remember, I will post the link. Keep up the good work! Do you work on the free or paid version?
I know how difficult it is to try and get pristine imagines through the hobby version of Twilight Render and would love to start a conversation about it. The hobby version is amazing but can't wait to purchase the full version. Please let me know if there is going to be, at least, a CPU/GPU render option. I run a great CPU, but would love to have the option to be able to run both my CPU and GPU to save some time on renderings/ use other programs that I might want to run at the same time. Sorry for the long thought. I love the Twilight Render Software but, please let me know of anything I could do to help further this application.
Thanks for listening,
- Jx Moss
- Jx Moss
Some Photoshop Touch! (exposure)
- 66.jpg (749.18 KiB) Viewed 9064 times
We can see the image is not as bad as you may think, as Nickario pointed out, the Exposure/Tone Mapping of an image is extremely important!
In my experience the correct Tone Mapping and good post-processing can make or break your image, and correct tone mapping can also save a less-than-exciting rendering.
The order of priority that you need to get right for great renderings is as follows:
Good model (includes vegetation) (make sure ground and walls and roof have thickness, and are built without cracks where light can creep in)
High quality textures/materials
Good lighting (includes sun/sky settings)
Good camera angle (your camera is cutting off part of the building, not advisable.)
Correct Render setting (I would try test images for this scene on Easy 02 or 03, and final setting of Easy04+ or for best results using Easy 09 for my final rendering. If you use Easy High or High+ disable caustics in the render settings)
Correct Tone mapping (you must increase exposure, play with Tone Map settings in the Render Dialog, search on our forum)
Great Post-processing (aka post-pro) for finishing, adding the polished touches to the image
appreciate all the tips everyone
