Hi everybody :
I'm having a problem creating lights. First, I'm using lights that I create in Sketchup 8. When I go to "create" the light(s), do I FIRST select the area where the light is to be shown (i.e. a table top, the floor, etc)THEN select the light source (the lamp itself) ? I watched the video several times. Sometimes, by accident, I CAN "create" the light, then set the parameters for the light. Sometimes, I get stuck and can't get the light "created".
stanulg
Creating Lighting
Re: Creating Lighting
You should follow this tutorial on the basics of creating lights:
https://www.twilightrender.com/index.ph ... utorial-v2
see tutorial linked by Chris above or this video tutorial linked below
3 clicks to place a light
move ligth object away from adjacent objects so that they do not intersect or conflict with 3D space taken by another object.
- anchor,
- position,
- target.
Fletch :
Thanks guys for your reply.....and advice.
stanulg
Fletch :
stanulg
