Rendering 3ds or obj imports into SU
Locked
barryrg
Post by barryrg » Fri Jun 01, 2018 4:06 pm
Is it possible yet to render 3ds or obj imports into SU such as from Xfrog?
posodrac
OS: i5 7th 16Gb W10
SketchUp: SU 17 Make
Re: Rendering 3ds or obj imports into SU
Post by posodrac » Sat Jun 02, 2018 2:37 pm
Once you import them to Sketchup, they not 3Ds or obj files anymore ;)
Post by Fletch » Sun Jun 03, 2018 4:38 pm
You can, with Twilight Render Pro, reference an external model as a proxy model. So you build something simple in SketchUp and make it a component, then link it to the external proxy model that would replace it when it renders.
However, that model needs to be in Kerkythea .xml format. Many Xfrog trees and plants are available as a library already for Kerkythea. Check Kerkythea.net for more info.
Locked
