Not had much time to render lately and not being happy with my modelling technique am leaving vehicles alone for a while. I will move on again when I have sorted a few things out style wise.
Gone back to looking at architecture, not being an architect, I have more interest in smaller properties and like to try going as small as I can without creating a different style of rabbit hutch. Something small only works for me if the proposed resident does not start chewing on the stair rail after a few weeks.
This render used 63 passes at progressive 04 and took 5 hours and 46 minutes aproximately. Comments welcome, if you do not like it, its ok to say so. I won't cry, much. Have a great week guys, cheerio.
Further Study.
Re: Further Study.
Surprisingly the render is quite good.
Probably you have already knew some of the problems.
Models, materials & lights....it's a long way to go.
Re: Further Study.
progressive o4?
wood flooring seems wrong scale.
obviously needs a lot of detail work... coming along nicely.
Re: Further Study.
I understand the render requires a bit more depth, just getting a feel for how I want it to go. As for the wood floor being the wrong scale, it is as intended. I wanted to give the impression of a custom made wood block floor. Not sure if it is a success, probably in the eye of etc.
Lighting was provided by making the entire ceiling a 60 watt bulb but it was only to see where I was at the time, different now.
Re: Further Study.
Still needs detail but I think there are signs of a result worth having. Possibly. Perhaps. I think I have to put in the personal touches now, flowers in a vase etc, otherwise it will remain rather sterile. This is not a completed render and I will leave it as long as I can. I am aware that I will not ger the higher standards of some here because I will not be leaving a render for the timescale of the pro's. I do like to try and improve though. Wardrobe doors will b e changed in the next version, I cannot get the material to work so will be looking to a wallpaper type of finish as an accent to the room.
Re: Further Study.
It's comming along nicely...
The floor texture seem off scale...
Also - it looks a little under exposed... Have you tried adjusting the exposure a little..??
Hope you don't mind, but I took it through a quick tone- and white balance adjustment using Adobe Lightroom...
(You can get the Lightroom 3 Beta here )
- QuatroStylo1easy09IntemediateStage-2.jpg (329.6 KiB) Viewed 9577 times
Re: Further Study.
I appreciate your comments, I will not improve without such feedback. You never know, I might become tolerably proficient. Thanks muchly.
Users browsing this forum: Bing [Bot] and 17 guests
