Hi,
When using batch render and rendering different scenes, twilight renders random scenes... Messing up the transition between the scenes: when switching from one scene to the next sketchup stops in-between the two frames... So that twilight renders in walls?
Reinstalled twilight and sketchup pro 2018. Didn't help...
Anny help would be appreciated!!
Batch Render messes up scenes?
Re: Batch Render messes up scenes?
What operating system are you using?
I've never heard of this issue occurring but it may be related to duplicated scenes when batch rendering on OSX. You might find it works better if you disable Scene Transitions (I think it's under Scenes->Settings?).
Window pull-down menu > Model Info > Animation > UN-check "Enable Scene Transition"
- SketchUp: 2023
Man - I googled this issue since I have a client who uses Twilight Render with this strange problem... I forgot I posted this myself a while ago...
I checked if this fixed the issue... AND IT WORKS!
Thank you Fletch and Chris!
Great! The next release of TWR will also have an option to choose between 2 different types of scene transitions for batch rendering. The newer releases of SketchUp seem to be unreliable using the old way, but work well using a different method.
