Hallo
I try to install the new version, but i have this error message ...
Errore di caricamento del file /Users/Gillo/Library/Application Support/SketchUp 2019/SketchUp/Plugins/twilight2/twilight2_loader.rb
Error: #<LoadError: incompatible library version - /Users/Gillo/Library/Application Support/SketchUp 2019/SketchUp/Plugins/twilight2/25/TwilightLibV2.bundle>
/Applications/SketchUp 2019/Sketchup.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in `require'
/Users/Gillo/Library/Application Support/SketchUp 2019/SketchUp/Plugins/twilight2/init_twilight.rb:25:in `<module:TwilightLoader>'
/Users/Gillo/Library/Application Support/SketchUp 2019/SketchUp/Plugins/twilight2/init_twilight.rb:5:in `<top (required)>'
/Users/Gillo/Library/Application Support/SketchUp 2019/SketchUp/Plugins/twilight2/twilight2_loader.rb:2:in `<top (required)>'
/Applications/SketchUp 2019/Sketchup.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require'
/Applications/SketchUp 2019/Sketchup.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load'
/Users/Gillo/Library/Application Support/SketchUp 2019/SketchUp/Plugins/twilight2.rb:15:in `register_extension'
/Users/Gillo/Library/Application Support/SketchUp 2019/SketchUp/Plugins/twilight2.rb:15:in `<module:TwilightLoader>'
/Users/Gillo/Library/Application Support/SketchUp 2019/SketchUp/Plugins/twilight2.rb:4:in `<top (required)>'
Some help ?
Sketchup 2019 Problem
Re: Sketchup 2019 Problem
Have you downloaded and installed the latest version of Twilight Render, v2.12? You may need to completely remove and delete any previously installed versions of Twilight Render for your SketchUp's plugins folder.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
