My own future house
Mike1158
OS: W10
SketchUp: V19
Re: My own future house
Post by Mike1158 » Tue May 26, 2020 6:49 am
Well, you will need windows rather than just glass panels so proper windows for a start.
jinacios2905
OS: windows
SketchUp: hobby
Post by jinacios2905 » Tue May 26, 2020 3:22 pm
Mike1158 wrote: Tue May 26, 2020 6:49 am Well, you will need windows rather than just glass panels so proper windows for a start.
Hello, Mike!
Thanks for the tip you gave. I was trying make this kind of windows above, but I think I need Thicker the frames to make more realistic and put brigthness and reflex.
Once again, Thanks for the tips... I'll improve it.
Jinacios :hat:
Post by Fletch » Wed May 27, 2020 12:32 pm
It is a pretty nicely done interior. :^:
The better your models, the better your renderings. If you have not yet seen them, follow the video tutorials in my signature "6 Essentials to Render in SketchUp with Twilght Render"
The exterior needs a lot of work. ;)
jinacios2905
OS: windows
SketchUp: hobby
Post by jinacios2905 » Wed May 27, 2020 5:50 pm
Fletch wrote: Wed May 27, 2020 12:32 pm It is a pretty nicely done interior. :^:
Thanks Fletch.
The most hard to me in exterior is the grass. If i could improve it and the sidewalk the rendering would seem way better. But seems that there is no way to make a texture grass look like real. If i Use a plugin to make grass, it increase exponentially render time, That already takes some hours coz I use my personal laptop to render and its GPU is weak.
Texture grass I tried, onle look better if seen from top.
Look this Backyard I'm working on now. Same grass texture, but the angle meke seems better!
Back yard Night (Medium).jpg (959.31 KiB) Viewed 9084 times
Jinacios :hat:
Post by Fletch » Thu May 28, 2020 8:11 pm
Fastest way is to simply photoshop the grass in. I typically do this with my exteriors just as a time saver.
Take a nice photo or two of different nice green lawns you see around you and use them. You will build up a library of content like this over time.
The more accurate your model and textures are the better your images will be. :^:
Grass works fine with Skatter or Fur plugin, if it's important to you.
jinacios2905
OS: windows
SketchUp: hobby
Post by jinacios2905 » Fri May 29, 2020 1:13 pm
Fletch wrote: Thu May 28, 2020 8:11 pm Fastest way is to simply photoshop the grass in. I typically do this with my exteriors just as a time saver.
Nice tip!
I'll Download one of these plugins, coz I'm using 3DArcstudio.
Need learn using Photoshop.
In time, please clarify uma doubt i have:
Applying material in both faces, instead of applying only in front face increses render time?
Jinacios :hat:
pbacot
OS: MacOSXMojave
SketchUp: 2019
Post by pbacot » Fri May 29, 2020 8:19 pm
I second the Photoshop grass approach. I am sometimes amazed, just grabbing a photo of a grassy hillside or even a whole scene off the internet or from my own photos, how it can work with my model. It takes, perhaps, an eye for scale and perspective, and sometimes you have to correct colors of model output or background to blend them nicely.
Post by Fletch » Sun May 31, 2020 2:09 pm
jinacios2905 wrote: Fri May 29, 2020 1:13 pm In time, please clarify uma doubt i have:
Not increase render times, but it will confuse you, because only front faces will render materials properly. Back face materials will result in error and confusion.
jinacios2905
OS: windows
SketchUp: hobby
Post by jinacios2905 » Sun May 31, 2020 10:04 pm
Fletch wrote: Sun May 31, 2020 2:09 pm
Thanks Fletch,
Asked coz I have some objetcts with both faces painted, Mainly 3D warehouse donwloaded components, So I wanted to know if i woul spend time Cleaning it.
Jinacios :hat:
Users browsing this forum: Bing [Bot] and 34 guests
