Lights inside glass Object
I tried to find the answer to my question on twilight render forum, manual and website. My question is: I've tried many options, but still, lights do not light up when I placed them inside the glass. Thank you for any help I can get on this forum.
Re: Lights inside glass Object
Can you post an example scene, and a description of what you expect? Often the solution is using architectural glass instead of "real" glass.
Creating Light Fixtures is a simple thing once you get used to it, but can be confusing at first.
Here's one tutorial about Lights inside of a glass object:
Subject: Light Bulb - aka "Come on, baby, light my bulb!"
Please follow the full new video series 6 Essentials to Rendering with Twilight Render - it is specifically designed to cover all major areas of working with Twilight Render. Modeling, Cameras, Materials, Environment, Lighting, and Rendering.
Note video number 5 is a very careful and thorough discussion of Lighting.
That said, the glass surrounding the light fixture must be set to "thin glass" which in Twilight Material Templates is "Architectural Glass>Common". You won't see the light object, as it's infinitely small, see explanation below:
Subject: Interior Lighting - Glowing Pendant Lights
Fletch wrote: ↑Sat Sep 28, 2019 4:15 pm It appears that you are rendering from the top looking down and you have the sun enabled.
Disable the sun. It is likely over-powering your other lighting.
Next, you will not actually see the twilight light object, it does not render as if it were a real light bulb. It is an infinitely small point of light, no matter what you tell the radius to be. The program will calculate the shadows as if the light is the correct radius, but it continues to be a theoretical perfect point of light.
In order to see a light bulb, you must insert a bulb.
For lighting architecture please watch our lighting for architecture video.
