Sun Room
tuna57
Sun Room
Post by tuna57 » Thu May 21, 2020 9:56 pm
Been away from SU and Twilight for months. Figured I'd better break it back out before I forgot what little I've learned.
Bashed together a little sun room scene. Rendered easy 9, 100 passes, minor post pro.
sunroom_Scene 3b copy-Edit .jpg (564.65 KiB) Viewed 813 times
pbacot
OS: MacOSXMojave
SketchUp: 2019
Re: Sun Room
Post by pbacot » Fri May 22, 2020 3:27 am
The light in the room and all is very real and looks great. The exterior is not as good as the rest, which is fully realistic IMO.
SketchUp: 2013-20
Re: Sun Room
Post by Fletch » Fri May 22, 2020 2:56 pm
+1 - definitely replace the background image. otherwise - very good!
tuna57
Re: Sun Room
Post by tuna57 » Fri May 22, 2020 4:48 pm
pbacot , Fletch , Thanks for the input. Agree the outside image could be a lot better. Used a spherical sky thats not to great. Really didn't want to go the route of "gimping" in the background. Probably will do some more experimenting with this one. cheers :!
Mike1158
OS: W10
SketchUp: V19
Re: Sun Room
Post by Mike1158 » Sat May 23, 2020 10:01 am
I agree with ^ but the room is nicely brought out in this, new background and it would be perfect. :clap:
tuna57
Re: Sun Room
Post by tuna57 » Sat May 23, 2020 7:32 pm
Thanks Mike. Posting a new render of this.... Swapped in a different spherical background image. Decided to turn out the lamp, got to save on the electric bill don't you know. Post pro Topaz and Affinity. Wouldn't mind to desaturate this particular spherical background image a little. Need to remember to take it into Affinity for some adjustments. Cheers !
sunroom_Scene 3B-PP.jpg (452.9 KiB) Viewed 765 times
tuna57
Re: Sun Room
Post by tuna57 » Sun May 24, 2020 6:23 pm
Last version of this I promise. Opened the background spherical image in Affinity , selected only the grass and desaturated it quit a bit. Tweaked the color of the lampshade a small amount . Also plumped up the pillows in these last two renders. Render settings stayed the same throughout. Fun practice to get back into the swing of things. Post pro
Topaz DeNoise and Affinity. :^:
sunroom_Scene 3c-PP.jpg (429.48 KiB) Viewed 750 times
pbacot
OS: MacOSXMojave
SketchUp: 2019
Re: Sun Room
Post by pbacot » Sun May 24, 2020 8:48 pm
Good calls. Excellent!
SketchUp: 2013-20
Re: Sun Room
Post by Fletch » Mon May 25, 2020 8:59 am
+1 :gj:
the models of the pillows are not at the same level of the other furniture models, IMHO. :|
Have you seen these? Free for Pro users: Pillows and Wicker / Ratan Ottoman "Poof"
tuna57
Re: Sun Room
Post by tuna57 » Tue May 26, 2020 3:44 pm
pbacot , Fletch , thanks for your input and I agree I need to refine my pillows some more , I'll end up with really good ones one of these days if I keep work at them. :^:
Users browsing this forum: Bing [Bot] and 8 guests
