Sun Room
Sun Room
Been away from SU and Twilight for months. Figured I'd better break it back out before I forgot what little I've learned.
Bashed together a little sun room scene. Rendered easy 9, 100 passes, minor post pro.
- sunroom_Scene 3b copy-Edit .jpg (564.65 KiB) Viewed 10305 times
Re: Sun Room
The light in the room and all is very real and looks great. The exterior is not as good as the rest, which is fully realistic IMO.
Re: Sun Room
+1 - definitely replace the background image. otherwise - very good!
Re: Sun Room
pbacot , Fletch , Thanks for the input. Agree the outside image could be a lot better. Used a spherical sky thats not to great. Really didn't want to go the route of "gimping" in the background. Probably will do some more experimenting with this one. cheers
Re: Sun Room
I agree with ^ but the room is nicely brought out in this, new background and it would be perfect.
Re: Sun Room
Thanks Mike. Posting a new render of this.... Swapped in a different spherical background image. Decided to turn out the lamp, got to save on the electric bill don't you know. Post pro Topaz and Affinity. Wouldn't mind to desaturate this particular spherical background image a little. Need to remember to take it into Affinity for some adjustments. Cheers !
- sunroom_Scene 3B-PP.jpg (452.9 KiB) Viewed 10257 times
Re: Sun Room
Last version of this I promise. Opened the background spherical image in Affinity , selected only the grass and desaturated it quit a bit. Tweaked the color of the lampshade a small amount . Also plumped up the pillows in these last two renders. Render settings stayed the same throughout. Fun practice to get back into the swing of things. Post pro
Topaz DeNoise and Affinity.
- sunroom_Scene 3c-PP.jpg (429.48 KiB) Viewed 10242 times
Re: Sun Room
Good calls. Excellent!
Re: Sun Room
+1
the models of the pillows are not at the same level of the other furniture models, IMHO.
Have you seen these? Free for Pro users: Pillows and Wicker / Ratan Ottoman "Poof"
Re: Sun Room
pbacot , Fletch , thanks for your input and I agree I need to refine my pillows some more , I'll end up with really good ones one of these days if I keep work at them.
Users browsing this forum: Bing [Bot] and 35 guests
