Hello, i finished work my last model and i want to add fog (with depth render). i use Sketchup fog distanse change to get realistic fog for my render, but everytime after depth render using, i get same result. for example, i want fog on backside of model and not in front, i change distance in sketchup and move fog line on back, but after render, fog is everywhere. can you help me and give me any suggestions?
Fog in Twilight render
- SketchUp: Sketchup 2020
Re: Fog in Twilight render
also i tried to turn off ''use background colour'' but it did not change anything
Melk-e-ART, please contact me via email at support@twilightrender dot com
Fog is not conntected to the depth rendering. You will have to change the appearance of the depth rendered image in photoshop using the "Levels" or "curves".
Thank you. i found, it was about GAMMA, i change it to 0.1 and it worked perfectly
btw where are you changing gamma? In postpro settings?
if you means this, yes. just gave it 0.1 and it worked well then in photoshop
Users browsing this forum: Bing [Bot] and 30 guests
