Desert Sky
- SketchUp: 2017
Desert Sky
I am trying to add realistic skies to my model, using Spherical Sky. I used the pack images, and got this result. Clearlly, the land part isn't a fit. Any suggestions?
- Treeline2008_Lawn rendering 1
- G1.png (1.88 MiB) Viewed 6318 times
- Treeline2008_Lawn rendering 2
- P2.png (2.19 MiB) Viewed 6318 times
Re: Desert Sky
You would need a spherical sky created with images shot from a similar height with a drone.
Subject: Horizon position with spherical sky
Subject: Scale an HDR Spherical Image to Match Your Scene (How To)
Subject: Controlling Render Background
- SketchUp: 2017
Re: Desert Sky
Thank you Fletch.
I don't have access to drone images, and some good desert background that I found (attached), are not seemless.
I see two issues with the existing image I used
1. The trees or houses at the horizon line, which are not suitable for my area, but also make the horizon looks very close, wherein my point of view they should be much far away.
2. The type of ground (water/green grass/desert send...)
Could you direct me on how to search for one without trees or houses on the horizon line, with some clear ground?
Is there a process I can control and set the horizon line on the background image?
- 6564x1727 Desert sky royalty free image
- Sky4.jpg (2.74 MiB) Viewed 6300 times
- 4000x2660 Desert sky royalty free image. Of course, these trees need to be removed
- Sky1.jpg (1.69 MiB) Viewed 6300 times
Re: Desert Sky
I linked you to the process above.shaisamuel wrote: ↑Wed Aug 05, 2020 7:55 pm Is there a process I can control and set the horizon line on the background image?
It may be difficult to find the background images you need. It is always a challenge for an artist to find the entourage they need for their work. You will need to take your own images, or buy what you need. Search for desert HDRI skies.
