Rending proble
Rending proble
Hello, I am very new in use of twilight render 2. . My problem is i added light and material in the scene when i am rendering only can see sky only blue to yellow. please solve my problem. Thanks
Re: Rending proble
Subject: Adding point light results in render of only background
Fletch wrote: ↑Tue Oct 15, 2019 5:25 pmPlease see this thread with your same problem:
- It's possible (most likely) that you have your light object selected and are rendering only the light object and nothing of your geometry. (you may have disabled notification of the warning that pops up asking if you wish to render only the selected object)
- It's possible you have set your "update geometry" to "none" it should be set to "all".
- It's possible there's a glitch from an older version of Twilight Render - please be sure you are using the very latest version only downloaded from our downloads page on our website.
- It's possible there is a vray component or some strange image file in your scene that are causing a glitch.
Subject: I see the sky when I render
