Hi all,
I am new to rendering and am using sketchup pro 2020 to render interiors. I have a particular model that is of a lampshade that is causing me difficulty. Its a download from the 3d Warehouse and it keeps rendering transparant and I can't work out why.
I have no understanding of translucency and alpha settings and thin this is what is causing me issues. I have tried changing the lighting settings but the model just won't display as a glowing pendant light as I'd like it to.
As a hobby user I have read lots of tips and tricks and before purchasing a full blown version I would like to understand if there are a glossary and deeper help information for starter renderers like me (I'm a teaching myself)
Thanks very much for your advise
Ivan
Transparency & Alpa in a model
- SketchUp: Pro 2022
- Screenshot 2020-11-14 at 12.48.32.png (1007.39 KiB) Viewed 5963 times
Re: Transparency & Alpa in a model
Make sure your faces are not reversed. (use Monochrome view in SketchUp)
Use Template:Lampshade> test the different templates there.
Subject: Using the Advanced Templates (v2.5)
If your model is built with thickness, or if it is a single face - will effect which material template you use. Also, your light setting inside the model will also matter.
Here's what it looks like as a single-faced (zero thickness) surface, with "Lampshade" template applied. (Rendered with Easy09 in 1.5mins and using Fastforward Denoise plugin )
(Example light fixture attached)
- PaperBall-pendant-TwilightRender.skp
- (280.41 KiB) Downloaded 416 times
- Untitled-1.jpg (515.21 KiB) Viewed 5958 times
For a shade with a texture image material applied to it, try the "Leaf" Template under "Translucent".
Users browsing this forum: No registered users and 21 guests
