glass magnifying
Posted: Fri Feb 05, 2021 8:18 pm
by rparsons
Help, could someone explain why the bookshelves beyond are magnifying in the glass. Thanks to all
- LIBRARY UPPER FLOOR 1_Scene 2 WITH NEW WALL1.jpg (600.07 KiB) Viewed 11750 times
Re: glass magnifying
Posted: Fri Feb 05, 2021 9:13 pm
Is your glass material using the Architectural Glass template? If not, you should switch it to that. It doesn't have any refraction in it and will prevent distortion from glass thickness.
Posted: Fri Feb 05, 2021 11:02 pm
Posted: Fri Feb 05, 2021 11:20 pm
by rparsons
Thank you Fletch for quick response. I will check the template on Monday. Will let you know the result.
Ron
Posted: Fri Feb 05, 2021 11:22 pm
by rparsons
Sorry, thank you also Chris!
Posted: Sat Feb 06, 2021 1:06 pm
As a pro user, if you apply the basic Grey or Blue glass from SketchUp, these should be auto-magically applied for you and render correctly "out of the box" this will not be the case if you "tweak" the materials or rename them or apply something different. In those cases, you will simply need to apply Architectural Glass>Common and it should look great.
Posted: Mon Feb 08, 2021 2:47 pm
by rparsons
Thank you! Thank you! The architectural glass was the trick.
- LIBRARY UPPER FLOOR 1_Scene 2 WITH NEW WALL1.jpg (666.51 KiB) Viewed 11716 times
