Volumetric render (Light)
- SketchUp: Sketchup 2020
Hello, i have one question. Twilight has Volumetric templete, but i want to know how to use it to get same effect, it is on image. Hope it is possible, because i am not Photoshop master to get same realistic effect, so i need to create it in render. also same result made by render is more relistic.
Re: Volumetric render (Light)
If you are looking for a scattering effect, you might be able to accomplish that using the Bloom post-processing effect.
Thank you Chris, can you explain how to do? i never have tried it yet
Bloom is found in Post-process tab.
Adjust the bloom parameters while your rendering is calculating or after it is complete.
It can be helpful, but will likely not give a volumetric scattering effect as in the example.
I used some subtle bloom in this image:
here it is without bloom:
Thank you Fletch. i try to find a way to get same skattering volumetric effect. i try a lot combinations with Twilight and photoshop, but cannot get it yet. i love Twilights photo realistic so much and rendering system. its so pretty. only i wish some little features in future and it will be perfect. (like volumetric skattering effect)
with love your user Melk-art-e
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 38 guests
