Hello there, i tried a lot ways to create deep material with doble bump. but have not idea how to create it
, can anyone explain it to me if it is possible
double bump in deep material
- SketchUp: Sketchup 2020
Last edited by GiorgiMelkadze3DArt on Sat Mar 27, 2021 10:49 pm, edited 1 time in total.
Re: couble bump in deep material
You can use only one bump map, or one type of bump. So you need to combine your two bump maps in photoshop before using them in the bump channel in Twilight.
Re: double bump in deep material
thanks Fletch, i already found the way how to use double bump. in BUMP feature i created layer and added two bumps and it worked well
Yes, you can use "added" or "multiplied" layers in the Bump channel in the deep editor.
You can use the Weights to mix them.
Here is a mix of the procedural Brick and procedural Marble textures.
- addedlayers.png (243.14 KiB) Viewed 6169 times
yes, this is what i did too, good way thanks Fletch
