Hi All, I'm new here and I've been working through the 'Twilight Render Tutorial Quick Start Introduction' tutorial.
I've got to the part where you insert a spherical sky which I've done and this is what happens...
Does anybody know what has happened and how I fix this?
Thanks
Spherical sky
Spherical sky
- my image is being split and greyed out in parts?
- tutorial1.jpg (735.99 KiB) Viewed 6044 times
- This is my spherical images
- green-landscape-sunny-day.jpg (1.51 MiB) Viewed 6044 times
Re: Spherical sky
Your sky image is not seamless. So you are seeing the seam. That is where the left-hand side of your sky image is being stitched together with the right-hand part of your sky image.
Fix it by making the sky a seamless sky in a photo editor. I like Photoshop for this. The latest versions of Photoshop allow you to use AI to fill in what is missing in a scene. Or, you can make the canvas of your sky image 2x wider, and mirror your sky image so that the sky will match at the edges. See example below:
After doing that, be sure to add some grass and sky top and bottom to make the final sky image of 2:1 proportion 2 width and 1 height. So 4000px wide and 2000 px high for example.
- Untitled-2.jpg (167.39 KiB) Viewed 6042 times
Re: Spherical sky
Seamless Sky version attached
- green-landscape-sunny-day-seamlessFixTWLsupport.jpg (4.81 MiB) Viewed 6032 times
Users browsing this forum: Bing [Bot] and 2 guests
