Hi everyone,
I'm satisfied with this external render, but my problem is the lawn. I used MAKE FUR but it is not realistic, I downloaded SKATTER on trial, I will use it in the next job, are there other alternatives? Only images inserted with photoshop?
Regarding the background, I followed one of your tutorials, but what should the image size and pixer / inch resolution be?
Thank you
Stephen
stone-clad house
stone-clad house
- MODELLO_A_01_2020_Scena4.jpg (4.89 MiB) Viewed 9265 times
- MODELLO_A_01_2020_Scene1.jpg (3.72 MiB) Viewed 9265 times
Re: stone-clad house
Welcome Stephen, as you can imagine, spherical sky images are a topic very well-discussed already on the forum, I am linking you to those discussions now.DEGIO59VANNI wrote: ↑Sat May 01, 2021 2:15 pm Regarding the background, I followed one of your tutorials, but what should the image size and pixer / inch resolution be?
Thank you
Stephen
The short answer is this: if you are rendering your final image at X pixels wide, the spherical sky will need to be 8x-16x pixels wide (spherical sky must be 2:1 ratio) to have a chance of appearing "sharp" in your final rendering. See graphic below. If you do not have enough RAM to handle such a large image texture for your sky, best thing is to render alpha mask and put a high quality image in using photoshop.
Subject: Sharper background
Subject: Spherical sky bright idea...
Subject: Spherical Sky output is very different from source
see also
Thanks so much, very kind as always!
Make fur is good- I think you need to choose a better model to instance with the plugin. Or perhaps the color is just overly / unrealistically saturated.DEGIO59VANNI wrote: ↑Sat May 01, 2021 2:15 pm Hi everyone,
Thank you
Stephen
Skatter gives amazing results in a few clicks, but is not required.
ps - the wildlife are not adding to the realism - If your goal is photorealism in SketchUp you may need to avoid living animals or people in your renderings unless it is the occasional distant bird.
thanks flatch,
I want to try to change color, thickness and length in MAKE FUR and then i will do an experiment with SKATTER
About wild animals I put them to laugh because the owner of the house saw wild boars, fawns and other birds nearby.
Hello and happy Sunday
DEGIO59VANNI wrote: ↑Sun May 02, 2021 8:35 am ...
About wild animals I put them to laugh because the owner of the house saw...
Users browsing this forum: No registered users and 47 guests
