A new light fixture for the next lighting components package release.
3 Pendant light with double glass tubes. Would look great over a dining table.
Pendant Light Glass Tubes
- pendant-glasstubes-50.png (998.25 KiB) Viewed 4688 times
- pendant-glasstubes-dtl.png (612.8 KiB) Viewed 4688 times
Re: Pendant Light Glass Tubes
Another Detail(s)
- pendant-glasstubes-dtl3.png (502.44 KiB) Viewed 4681 times
- twisted wires in plastic insulation
- pendant-glasstubes-dtl4.png (854.8 KiB) Viewed 4680 times
How do you find a dynamic view for your renderings?
Do you put much effort in your camera angles?
How important are camera angles to selling your design?
DOF can add significantly to render times, is it worth it?
Have you used the Z-Depth Render Pass to add DOF in post pro? It's a great alternative as it takes seconds to render the depth pass, and Photoshop allows you to adjust lens blur using that mask in the alpha channel of your rendered image layer.
- pendant-glasstubes-dtl6.jpg (524.26 KiB) Viewed 4670 times
- pendant-glasstubes-dtl5.jpg (526.13 KiB) Viewed 4670 times
- pendant-glasstubes-dtl7.jpg (443.56 KiB) Viewed 4667 times
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 42 guests
