Hi,
I'm adding two lights to the scene, at first , each one is a separate entity, but somehow, after a few tweaks all the lights start to inherit the same parameters, even the name of the light appears the same.
Thanks,
Lu
All light change at the same time
Re: All light change at the same time
If you copy a light object to a different place and change the parameters all copies of that light will take on those new parameters.
To create 2 different lights you must use the light creation tool to create the second light separately.
Twilight Render lights are SketchUp Components. Just like any SketchUp component, if you change the internal values of the component, it is reflected in any and all instances of that component in your scene.
