Can't seem to get rid of this vertical light streak that appears in my texture (circled in blue in the screenshot.). I have changed the size of the texture several times, but no help.It is currently 6" x 6"
Please advise.
texture with vertical streaK
- Screenshot 2023-04-01 at 7.07.38 AM.png (4.55 MiB) Viewed 1745 times
- Screenshot 2023-04-01 at 7.07.38 AM.jpeg (879.13 KiB) Viewed 1745 times
Re: texture with vertical streaK
please post the texture image which is giving you problems here.
share a piece of the .skp model where the problem is and we can help better. I would just be guessing without them.
have you tried
https://architextures.org/ ?
have you tried
hey fletch
As per your suggestion, I am now using a texture I downloaded from Architectures. However, I can't seem to get it to shine.
Please advise
Please advise
- not shiny.jpg (502.71 KiB) Viewed 1723 times
Your scene, camera viewing angle, and the lighting leave nothing to reflect back. So it looks terrible, but that's not the fault of the material.
Read the names of each image below to see about viewing angle and material template used.
- tile-gloss-front_overhang-easy7-sphericalsky-02.jpg (227.24 KiB) Viewed 1713 times
- Tile-perfectreflection-front_overhang-easy3-sphericalsky-02.jpg (230.3 KiB) Viewed 1713 times
- tile-perfectreflection-front_overhang-easy7-sphericalsky-02.jpg (232.27 KiB) Viewed 1713 times
- tile-perfectreflection-front_overhang-easy7-sphericalsky.jpg (224.85 KiB) Viewed 1713 times
- tile-perfectreflection-high_overhang-easy7-sphericalsky.jpg (202.68 KiB) Viewed 1713 times
- tile-perfectreflection-high_overhang-easy7.jpg (187.31 KiB) Viewed 1713 times
- Tile-perfectreflection-high_overhang.jpg (190.7 KiB) Viewed 1713 times
- tile-gloss-high-overhang.jpg (188.83 KiB) Viewed 1713 times
- tile-gloss-front-overhang.jpg (168.46 KiB) Viewed 1713 times
- tile-gloss-front.jpg (163.62 KiB) Viewed 1713 times
- Tile-PerfectReflection-high_front.jpg (165.7 KiB) Viewed 1713 times
- Tile-PerfectReflection-high.jpg (212.57 KiB) Viewed 1713 times
- Tile-gloss.jpg (207.73 KiB) Viewed 1713 times
- default.jpg (198.63 KiB) Viewed 1713 times
see attached file as an example
Users browsing this forum: Google [Bot] and 55 guests
