spherical sky
- SketchUp: 7.1 pro
spherical sky
How can you see in twilight render that your images is correct lined up with your background.
In this example i used a spherical sky image, and when you look at it, you could see that the test image nog correct is lined up with the background.
Is there a tutorial or a trick to learn.
Thanks for the understanding and help
- test.jpg (307.36 KiB) Viewed 12417 times
Re: spherical sky
Well you've probably read the other topic about this by now, the one I started
EDIT: I wrote a lot of rubbish here that didn't make sense (even to me) after reading it. The other topic Chris linked to should be enough hahaha...
What did make sense was this bit: And another thing that makes your model look 'floating' is the lack of a boundary. I added some quick-n-dirty grass in Photoshop and it already looks less like a UFO (in my opinion at least).
- Added some grass in PS
- grasspp.jpg (356.16 KiB) Viewed 12407 times
Re: spherical sky
Spherical skies do not receive shadows.
This spherical sky is intended to be providing great reflections in windows, as a window with no sky will reflect the sky color and everyone says "how come the window isn't reflecting anything?" and we have to say "it can't reflect anything if there's nothing to reflect...
you see.
This spherical sky is intended to be providing a great background for interiors as well... so if you are inside a building, and you look out the window you see a nice distant grass and treeline.
This spherical sky is intended to be a great background when you have enough fore-ground objects in your scene to cover up the horizon line on down...
here's a perfect example...
you see.
- SketchUp: 7.1 pro
Re: spherical sky
Thanks a lot i know that i must work on a good foreground and perhaps sometime's a litte bit photoshop or paint shop pro.
But 1 question, how do you know the distance between your object en the beginning. Or better said what is the size of your image when your render.
In my first picture the object was in the middle of the picture, but in my skecthup window is was standing in front. How do you manage the distance and
de window rendering
de window rendering
Re: spherical sky
it appears in your first image that the spherical sky is not loaded into the Spherical Sky Type.
Or, it appears that you are using an extremely wide viewing angle, your camera in SketchUp appears to be greater than 70 degrees, or even maybe 90?
Or, it appears that perhaps you are using a 2-point perspecive modified camera in SketchUp.
In any of these cases, the spherical sky may appear distorted.
As you can see in my example above, you can not see NEARLY as much "sky" as you can in your image. So the camera setting in SketchUp is definitely something "special" in your case. You can see in my example the clouds appear to be a natural scale.
That said, it does not appear that the view is "messed up" to me.... I am assuming that one of the cases I listed above is true.
If you are using the two-point perspective camera in SketchUp, this will render ok, but only if you do not PAN the image, or change it from how it is at the default position when two-point perspective was chosen. If you have panned or rotated the view after that in any way, your rendered image results will not match the SketchUp view.
For more discussion on Spherical Skies, please see this thread.
- SketchUp: 7.1 pro
Re: spherical sky
After some test i achieved a little bit what i want, but otherwise your right to say that the best possible solution is to design a larger picture where the background only the sky should be.
So i stick to that point.
- test2.jpg (243.84 KiB) Viewed 12347 times
- SketchUp: 7.1 pro
Re: spherical sky
After some new test, i think i got it under control (for a beginner then). Just see the image from a house (not designed by me) and in the background the hills of Austria.
The only thing is just don't get right is the sharpness of the background, in my opinion it is not sharp enough. Can any one tell me wat to do with that.
Perhaps it is the size for the background ?
Re: spherical sky
the 'sharpness' of a background image has only to do with the original resolution of the image used as a background, and with the final resolution of the rendered image.
If your background image is 800px wide, and your final rendering is 2400px wide, then the image will look very grainy because it will be stretched to fill the 2400px wide rendered image.
Here's a good explanation on our forum with diagrams.
If you want to learn more, Rafa has created some very nice diagrams you can read all about it, and very very well explained for beginners.
Please look closely at Rafa's great tutorial on HDR and sphericals, globals, etc.[/quote]
- SketchUp: 7.1 pro
Re: spherical sky
Fletch,
Thanks for the information, but i can't read the information on the forum (no authorisation). But by the way your file is the same as from the video tutorial. Do you have the .skp file so i can also follow the tutorial with the original file.
Thanks in advance.
Thanks in advance.
