About Displacement
About Displacement
Hi, is it possible to recreate with Twilight the "Displace" feature of other renders. I tried using a black&white bumpmap but the corner effect did't look like the example attach made with Indigo. It gives the effect that one wall enter through the cracks between stones on the other.
- sceneBonsai01cut.jpg (690.39 KiB) Viewed 7881 times
Re: About Displacement
No, Twilight does not support displacement.
ANy change you guys on working on it ?
The render engine behind Twilight Render (TWR) is Kerkythea...dutchesse wrote:ANy change you guys on working on it ?
When/if KT will get displacement implemented, it will also become available with TWR...
A few lines traced on that plane and a little push-pull will do the trick.
poseray is free, has displacement, and can be brought into SU (Imported as obj)
Yes... tricks is what us latins do best, gracias.Ecuadorian wrote:A few lines traced on that plane and a little push-pull will do the trick.
