i would like to make an animation using one of the sketchup pencil styles. is there anyway that twilight can be used to export using a sketchup pencil style?
thanks
pencil style
Re: pencil style
only in post-pro vid. production... you would export a black and white sketchy vid out of SU
you would render the same vid in TWL
then merge the two in a video editor that allows "multiply" layering.
Re: pencil style
beckdan, is you refer to the SketchUp styles, I assume you can also export the animation directly from SketchUp's File > Export > Animation dialog.
Re: pencil style
i only have the free version at the moment and before i purchased the full version i was curious if twilight has this feature...
Re: pencil style
The pencil styles are very specifically "Sketchupy" (especially since you can configure your own!). So there is no way for Twilight to capture the same look. Rendering the animation, then exporting and overlaying the SU animation is the only way to capture the pencil styles.
Users browsing this forum: Google [Bot] and 8 guests
