Need Help- UV tools [resolved]
Re: Need Help- UV tools
miguel: its grouped.
I have uploaded the model to box.net....link is further up this thread.
this is really annoying cos UV tools is a fantastic plugin....sometimes!!
Oli
EXPLAIN!!
it seems only the base renders correctly though. from the base upwards there is no bump. what did you do?export then import?
Oli
Used Vue to map texture.
- uv mapped.png (138.37 KiB) Viewed 12503 times
hmmmmmmmmmm
I tried wings but it didn't like the obj for some reason. I keep getting jagged geometry sticking out of it! I'll have to learn another uv mapper . i cant get my head round blender; there are just too many buttons!!
Oli
seems there's something odd, Oli, with the texture mapping which you say is "perfect."
don't know if it's SU, UV tool, or TWL, or combination of some or all of those...
here's an example...
did you scale the base after building/mapping it?
- pot2-baseworking.jpg (64.59 KiB) Viewed 12474 times
- uvmappingissue.jpg (170.74 KiB) Viewed 12476 times
so based on that experiment, I realized it was just a texture scale issue on the base, and a matter of better Anti-aliasing.
template: Brushed Metal Silver
renders perfectly. check it out.
- uvmappingissue-fixed.jpg (124.42 KiB) Viewed 12476 times
- pot2-fixed.zip
- (1.19 MiB) Downloaded 544 times
bloody fantastic news there Fletch!! those renders look amazing!!
gonna do some testing now.
looks like you have the texture in the color channel...which I didnt. it was just the bumpmap if that makes any difference.
I scaled down the scratchmap texture because it looked huge in Sketchup. so I guess I should just leave it as it is....it doesn't actually render as it appears. I scaled it down x5 from 250mm to 50mm so that it looked correct.
right Im on it now Fletch, those renders are fantastic!! cant wait to do the whole range of planters they are very nice....my mum is the designer!
Oli
test of just the base. using brushed metal silver.
bump looks fine....then theres a weird wavey bump half way up?!!
used same preset as you. hmmm
I have the old twilight too, could that cause any probs? gonna download new one now.
quick test with your version of the pot: works perfect and i cant understand why yours is different to mine!!
- test4.jpg (75.56 KiB) Viewed 12449 times
- test5.jpg (81.22 KiB) Viewed 12446 times
Oli
mate its the old twilight thats causing the problem......or am I just imagining that?
just installed the new twilight, retextured using the same method...and it works perfect...absolutely no problems.
Oli
Users browsing this forum: Ahrefs [Bot] and 71 guests
