Re: How Fast Are You - Official Twilight Scene - Bauhaus Lamp
Downloaded your latest .skp version.
No render method chosen: 33 sec
Render method "Low" : 33 sec
Is this latest version different than the previous one? That's a pretty large change from 20 sec to 33 sec
- Lamp.jpg (108.09 KiB) Viewed 17089 times
- Lamp - Low.jpg (122.46 KiB) Viewed 17097 times
SU 7.1 and Win 7
SU 7.1 and Win 7
ah, much better! Well, not sure what happened. Glad the camera is set correctly. Thanks for the follow-up.
With the lamp occupying more pixels, there's more to anti-alias, and that is the process that can take a lot of time.
- SketchUp: 8
My test on W7 64 bits.
image attached by admin
- probatwilight.jpg (111.03 KiB) Viewed 17019 times
Well it looks like I am the first to submit some results using an AMD powered PC. What can I say, I like being a little different.
AMD Phenom II X4 965 Processor 3.4 GHZ
8.00 GB RAM
Windows 7 64-Bit
8.00 GB RAM
Windows 7 64-Bit
- Twilight Test.jpg (396.98 KiB) Viewed 17007 times
My results.
- Captura.JPG (86.18 KiB) Viewed 16985 times
I'm getting the same issue as Scott, I tried both the skp and zip but view is further away, not sure how to correct it.
I got 17s but it's wrong view.
clicking "Scene1" doesn't choose the correct view?
What screen do you have? This is done with a widescreen.
- Scene1.jpg (35.25 KiB) Viewed 16929 times
I'm using 2x 42" LCD's in dual mode.
I guess, just do your best to get it close to same view as you can... I'm not sure what could cause this. Maybe it's an issue with screen resolutions or something? (doesn't make any sense)
I did not have an issue with the file. It worked correctly. I am running dual 30" screens and that did not effect correct results.
scott
scott
Users browsing this forum: Google [Bot] and 17 guests
