Page 1 of 2
Realistic Water - Fast - in Twilight Render
Posted: Sun Aug 30, 2009 6:59 pm
You can download the scene for yourself here:
Here's how: (click image to remove scroll bars)
- WaterInTwilight.jpg (133.03 KiB) Viewed 42769 times
Here's how it looks:
- WaterTutorialScene_Easy05_Med+_56s.jpg (32.33 KiB) Viewed 42961 times
Re: Realistic Water - Fast - in Twilight Render
Posted: Sun Aug 30, 2009 8:41 pm
by fymoro
Thanks Fletch.
Posted: Sun Aug 30, 2009 11:17 pm
by Boofredlay
Nice, thanks.
Posted: Mon Aug 31, 2009 8:56 am
by Dylan
Good tip about un-linking color, I thought you had to change material completely to one that had color you required.
That way is much easier.
Posted: Fri Nov 13, 2009 6:39 am
by d12dozr
Nice mini-tut, Fletch...I downloaded the model and played with the settings - now can you explain why you unlink and change the color and reflections to white? I think it looks too white that way...please help me understand
Posted: Fri Nov 13, 2009 10:30 am
remember that the sky in this model is set to white and no sun/shadows - so to see how the water will 'truly' look in your scene, you need to set it up in your scene.
white = "clear" water... if you don't unlink the color
first but just change it, it will change in the SketchUp water material... but if you
unlink the color before you change it, you can render it with any look you want in Twilight, but "leave the SketchUp looking water" the same as it appears in SketchUp.
If you unlink, then change the color to brown, or another texture, you will get a different "look" but you will need to render it to see the difference because the SU texture is now
unlinked and independant from the color in Twilight.
Posted: Fri Nov 13, 2009 10:48 am
changing opacity of the water will make it "darker" or "murkier"
This one is made by typing in the name for the color "Brown"
Then setting opacity to "80" percent opaque.
using "Medium+"
Posted: Fri Nov 13, 2009 11:48 am
solid glass option using Cyan as color and reflection color
Posted: Sat Nov 14, 2009 9:02 am
by d12dozr
Thanks, Fletch
cheers
Posted: Thu Mar 17, 2011 11:29 pm
by JGA
Thanks for the information - & to Majid for sharing the materials.
