Polycarbonate material
Made this long time ago and was already posted in KT's forum, but I post it here just in case you missed it together with some "new" instructions on how to change it.
There are three "flavours":
- a clear one
- a coloured one
- an edges coloured one.
They are made with two mixed layers: a transparent one and an opaque one, so if you want to change the transparency (or the colour) just export the material to KT and follow the instructions.
Also you can make "fake" panels just by applying a bump map to your model. Here I've used a striped texture.
Remember that the models must have thickness and use preferably with unbiased presets.
Be careful, long render time.
Hope it's useful.
P.S. The renders are made with KT.
- a clear one
- a coloured one
Hope it's useful.
Re: Polycarbonate material
Now the instructions...
- Cattura.JPG (171.14 KiB) Viewed 31585 times
- Cattura_1.JPG (173.94 KiB) Viewed 31584 times
- Cattura_2.JPG (146.22 KiB) Viewed 31582 times
...one more and the mats.
- Cattura_3.JPG (160.43 KiB) Viewed 31577 times
- polycarbonate.zip
- (39.31 KiB) Downloaded 1478 times
Very nice, Massimo, thanks!
This is a difficult material to achieve, and it looks really good.
My pleasure.
Thanks for adding the link about how to export the material in Kerkythea.
Thanks
Theres something I dont understand...
The 2 first screen captures show how to change the translucency. Are the other 2 working together too? What does falloff do?
On your chairs render, you should add a back-pocket button scratch bump map, It would look more realistic
Not in the examples I've posted, but of course they can work together. In the first (the coloured one) you just change the colour of the material itself, while in the second (the edges coloured one) you change the colour that will be absorbed from the light spectrum (falloff). Also the materials have quite accurate Abbe number (dispersion) and IOR.Are the other 2 working together too?
Oh and the render was just a rough quickie just to test the mats.
Oh... Thanks.massimo wrote:Not in the examples I've posted, but of course they can work together. In the first (the coloured one) you just change the colour of the material itself, while in the second (the edges coloured one) you change the colour that will be absorbed from the light spectrum (falloff). Also the materials have quite accurate Abbe number (dispersion) and IOR.
I dont quite understand yet whats under the hood, but I think your library will be very useful.
It is always a joy to have the opportunity to learn from the masters.
- SketchUp: 8 Pro
Thanks for the material, you always amaze me!
You're welcome.
