Maintenance Release Twilight Render 1.0.6
The latest about Twilight
Locked
Post by Chris » Tue Sep 01, 2009 3:05 pm
Hello All,
There is a new maintenance release available here, version 1.0.6.
In this release you will find:
  • A fix for background images not rendering correctly
  • An option to turn on and off the use of layer visibility in components
    • Right click on the component in question.
    • Select Twilight
      • To turn on and off layers for just this component, select 'Use Layers in Component' to enable layer visibility, 'Ignore Layers in Component' to disable layer visibility
      • To turn on layer visibility for all components, select 'Force Layer Visibility in ALL components'
    • Transparent TIF handling for clip mapping
    • Added button to Options->Dialogs to 'reset' the saved location of Twilight dialogs, like the render dialog.
Just install over the top of your previous installation. No need to uninstall first.
Locked
