Glossy Concrete floor - with Spec/Bump/Image Maps...
Posted: Thu Nov 24, 2011 5:27 pm
by bradleyabbott82
Here is a concrete floor I've been working on... Works great in modern spaces with a Bump of .3 using the attached bump/spec maps... I've attached some examples... These were both set with image/bump/spec maps as attached with a bump setting of .3 using the "polished Stone" template -- I set Shinyness to anywhere between 10k-85k depending upon the situation and how "rough" I want it to look...
Enjoy!
File Link:
http://97.77.209.118:9500/ConcreteFloorSquares.zip
*edit by admin - host link at Twilight Render* Concrete Floor Squares material (4Mb)
- Example 1 - Bump .3 Stone Polished Template; Shininess 50k; IOR 1.6
- 6PANEL-PROPDEVELOPERS-AD-reducedforum.jpg (461.36 KiB) Viewed 15440 times
- Example 2 - Bump .3 Stone Polished Template; Shininess 50k; IOR 1.6
- 6PANEL-PROPDEVELOPERS-AD(view2)-reducedforum.jpg (538.39 KiB) Viewed 15439 times
- Example 3 - NO BUMP, NO SPEC, IOR 1.6; Stone Polished Template; Shininess 5k
- MELLY-IMAGE2(EASY9-107PASS-11H16M)-postpro(50percentsized).jpg (322.1 KiB) Viewed 15435 times
Re: Glossy Concrete floor - with Spec/Bump/Image Maps...
Posted: Thu Nov 24, 2011 11:18 pm
by unclebim
Thank you, nice renders.
Posted: Fri Nov 25, 2011 9:58 pm
Thanks for sharing, Bradley!
Posted: Fri Dec 02, 2011 9:04 pm
by dorfpunk
cool, thatnks for that
Posted: Mon Mar 26, 2012 8:49 pm
by meriil
thanks for sharing, just what i was looking for!
