Page 2 of 3
Re: How to fake fire flames
Posted: Fri Sep 11, 2009 3:21 am
I don't know what the pot material is, but I suspect it's just a light leak. You are using the lowest setting, so light leaks are certainly possible.
Posted: Sat Sep 12, 2009 3:08 am
by xrok1
i figured where the light is coming from (not a leak).Its sky brightness. this seems strange to me, i would think if the sun is disabled that the sky should be disabled, and why does the preliminary render (no preset)not take the sky into consideration?
is this how things should work?
Posted: Sat Sep 12, 2009 3:15 am
"no preset" is more of a bug than anything. But yes, that's exactly how it's supposed to be. With no preset, the sky doesn't contribute lighting. You can disable to sky by setting the background color to black, as I said before.
Posted: Sat Sep 12, 2009 3:27 am
by xrok1
ok, thanks. the point light was way too bright in the original file for me to see the effect properly. now that i changed it to .1 everything makes a lot more sense
Posted: Sat Sep 12, 2009 8:03 am
If we linked turning off the sun with turning off the sky, we'd get a lot of complaints and problems from everyone, I'm afraid,
so it takes some getting used, to , but if you want to disable sky light, must set sky to use 'background color' and pure black... it's 2 extra clicks, but becomes 2nd nature after a few tries.
Posted: Sat Sep 12, 2009 5:18 pm
by xrok1
i wonder if a
Sky enabled checkbox wouldn't be in order, just like the
Sunlight enabled one? that way we wouldn't have to try and remember the backgrounds color, it could be just switched off.
ps could be more clicks if your background isn't already set to
Background Color .
Posted: Sat Sep 12, 2009 11:03 pm
by Gareth
great tip.....thank you...!!
Posted: Fri Oct 16, 2009 2:58 pm
by Gaieus
Thankf for the tip and the flame material, Miguel! I have started to use in in my Roman basilica project already
(and had some interesting observations in
Tom's 2.5D tree topic)
Posted: Mon Jul 19, 2010 8:12 pm
by Bloodix
This thread is so usefull, thanks !!!
Posted: Wed Mar 16, 2011 9:18 pm
by tqb780
THANKS FOR POSTING...ITS REALLY GOOD
