Page 2 of 3
Re: OS X Mavericks
Posted: Tue Dec 17, 2013 9:04 pm
by John
I have 16gb of ram. I will give another test run while watching the ram amount being used. Once I have the data, I will let you know. Thanks!
Re: OS X Mavericks
Posted: Tue Dec 17, 2013 10:09 pm
by John
OK, here's what happened this time. While rendering at Prelim, the amount of memory used was roughly around 2.32 gb. The scene finished rendering. When I was waiting for the fan speed on my computer to drop back to normal (about 1.5 minutes) SketchUp crashed. Closed down. Boom. When I restarted SketchUp, I tried rendering on Low. Render was going fine, memory was running around 2.77 gb, but when the rendering reached 65%, (about 5 minutes into rendering as noted by the timer at the bottom of the render window) the rendering processed stopped. Even though the timer was still running and the percentages were still climbing, it was no longer rendering - the render was not changing - it just froze. Once it reached 100%, the "threads" count at the bottom dropped from 8 to 7, the percent window went to 0%, but the timer kept counting up. After I waited a couple of minutes, I manually stopped the render, but it wouldn't stop. Basically, the render was stuck in a loop. I tried to shut down using the "X" on the top right of the window, but I got a message that the rendering was still active and would run in the background even if I closed the window. Then SketchUp crashed, again.
I still think it's a Mavericks problem. But, while testing this, I just got a notification from Apple that a new update for the OS is available. Maybe that will solve the problem.
Re: OS X Mavericks
Posted: Tue Dec 17, 2013 11:35 pm
sounds like either the system is over-heating, or the RAM limit could be crashing it. as SU is a 32bit app, so is Twilight. This means you have a max of 4gb allocated by the OS, as far as I'm aware. Perhaps Mac allocated RAM differently, but as I understand 32 vs 64 bit, 32 bit address space can only access 4Gb. So. please try rendering on Easy 09 and let us know the result. Or try changing the render setting to drop photon shooting to lower RAM requirements for the light photon map.
Subject: 32bit RAM limit
Subject: Easy 1-7 Photon Mapping and Final Gather (Biased)
Re: OS X Mavericks
Posted: Wed Dec 18, 2013 3:24 pm
by John
I figured out what I believe was the cause of the crashing. I had a gazillion trees in my scene. After reducing the quantity of tress, everything worked fine. I been rendering for about an hour (medium+_AA4(ultra)) and it's running without any problems. I guess with all of those trees the photons kinda freaked out because of all of the extra bouncing around they had to do. (enough to make my head hurt)
Fletch, if I am correct, if SketchUp went to 64 bit, would the program then be able to allocate more memory? What I understand about the difference between 32 and 64 bit was that 32 bit was limited to 2 gb while 64 bit could use 3-4 gb (depending on operating systems). And the more memory, the smoother the rendering process would be. Also, what about the processor itself. is SketchUp able to take advantage of multiple processors? If I had a computer with 2-3.3ghz processors would SketchUp (and therefore, Twilight) be able to use both? Thanks!
Oh, and I did install the update from Apple yesterday. I don't know if that made any difference because the update didn't seem to address anything relevant, as far as I could tell. Apple listed that the main issues for the update had to do with Gmail, blah, blah, blah. But it also mention improved stability and capability, which I would venture to guess is just a catch-all phrase.
Re: OS X Mavericks
Posted: Wed Dec 18, 2013 8:45 pm
Twilight Render can use all of your processors to render. By default, it will automatically use all of them but you can change that under the Advanced tab of the render window.
If SketchUp ever went 64 bit, it would be able to use effectively unlimited memory. There is a limit but it's so ridiculously high you'd never reach it. It wouldn't effect the speed of Twilight Render or SketchUp but would allow you to render more complex scenes, larger textures, etc.
Re: OS X Mavericks
Posted: Thu Dec 19, 2013 6:28 pm
by JakeMM
Sketchup only uses one processor, but Twilight can use more than one if your processor supports hyper threading. Also check out turbo boost on some processors. This allows one processor to speed up if the others aren't being used and gives more benefits when modelling. For example, I have a 2.5Ghz dual core, but when just using one core, my laptop can speed up to 2.9 Ghz and so there is some benefit to having more than one core.
Also good to know you've worked out what was causing Sketchup to crash. The latest update for Mavericks seems to just be a couple of tweaks to Mail. If any Sketchup issues do come up, it'll most likely have to be Sketchup releasing a compatible update, rather than Apple changing anything back.
Re: OS X Mavericks
Posted: Mon Dec 23, 2013 9:39 pm
by Cody
John wrote:BTW, Cody, how were you able to downgrade back to Mountain Lion? I tried a clean install back to Mountain Lion but the only option it gave me was Mavericks.
Nope, new macbook would not let me downgrade - also voids applecare. have to make do.
It's still crashing 1 of every 10 exports. that's not cool.
Re: OS X Mavericks
Posted: Mon Dec 23, 2013 9:46 pm
by Cody
here's the crash report sent to apple (they don't care)...I sent it to the sketchup team. now I'm sending it to the twilight team. twilight team, you guys are great, sorry apple screwed the pooch.
macbook pro quad core
16 gb ram
nvadia graphics card
To infinity and beyond!
Process: SketchUp [30169]
Path: /Applications/SketchUp 2013/SketchUp.app/Contents/MacOS/SketchUp
Identifier: com.sketchup.SketchUp
Version: 13.0 (13.0.4811)
Code Type: X86 (Native)
Parent Process: launchd [139]
Responsible: SketchUp [30169]
User ID: 501
Date/Time: 2013-12-22 21:25:47.094 -0600
OS Version: Mac OS X 10.9 (13A3017)
Report Version: 11
Anonymous UUID: 8E00F485-9266-2F2C-4095-5DE8E0CEC3A8
Sleep/Wake UUID: DF7AF300-AC3F-4A94-9C24-BFCE8446B206
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/SketchUp 2013/SketchUp.app/Contents/MacOS/SketchUp
__TEXT 0000000000001000-000000000076a000 [ 7588K] r-x/rwx SM=COW /Applications/SketchUp 2013/SketchUp.app/Contents/MacOS/SketchUp
Application Specific Information:
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x920b8952 __pthread_kill + 10
1 libsystem_pthread.dylib 0x946aa167 pthread_kill + 101
2 libsystem_c.dylib 0x990c1340 abort + 155
3 TwilightWidgets.so 0x33be9426 OpenRenderDialog + 2449702
4 libsystem_platform.dylib 0x950e4deb _sigtramp + 43
5 ??? 0xffffffff 0 + 4294967295
6 com.apple.CoreServicesInternal 0x9aee0638 BookmarkMutableData::encodeItem(unsigned int, void const*, unsigned int) + 62
7 com.apple.CoreServicesInternal 0x9aee4294 encodeResourcePropertyIntoBookmark(BookmarkMutableData&, __CFURL const*, __CFString const*, unsigned int, __CFError**) + 83
8 com.apple.CoreServicesInternal 0x9aee44ed addVolumeInfoForURLToBookmark(__CFAllocator const*, BookmarkMutableData&, __CFURL const*, unsigned long, unsigned int, __CFArray const*, __CFError**) + 471
9 com.apple.CoreServicesInternal 0x9aee3d4f createBookmarkWithURLAtDepth(__CFAllocator const*, __CFURL const*, unsigned long, __CFURL const*, __CFArray const*, BookmarkMutableData&, unsigned int, bool, __CFError**) + 5783
10 com.apple.CoreServicesInternal 0x9aee22ed _CFURLCreateBookmarkData + 1201
11 com.apple.LaunchServices 0x983e3917 LSSharedFileListInsertItemURL + 494
12 com.apple.AppKit 0x99618c1f -[NSDocumentController _readRecentDocumentDefaultsForKey:] + 720
13 com.apple.AppKit 0x99618377 -[NSDocumentController(NSPrivate) _startResolvingRecentDocumentURLsForKey:includingResolved:completionHandler:] + 145
14 com.apple.AppKit 0x99817837 _recentItemListDidChange + 59
15 com.apple.LaunchServices 0x983e4040 LSSharedFileListCallback + 32
16 com.apple.CoreFoundation 0x9008e2c8 __CFMachPortPerform + 440
17 com.apple.CoreFoundation 0x9008e0f5 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 53
18 com.apple.CoreFoundation 0x9008e05b __CFRunLoopDoSource1 + 523
19 com.apple.CoreFoundation 0x9007e822 __CFRunLoopRun + 2130
20 com.apple.CoreFoundation 0x9007dd5a CFRunLoopRunSpecific + 394
21 com.apple.CoreFoundation 0x9007dbbb CFRunLoopRunInMode + 123
22 com.apple.HIToolbox 0x90398e2d RunCurrentEventLoopInMode + 259
23 com.apple.HIToolbox 0x90398bb2 ReceiveNextEventCommon + 526
24 com.apple.HIToolbox 0x9039898d _BlockUntilNextEventMatchingListInModeWithFilter + 92
25 com.apple.AppKit 0x9931c5a9 _DPSNextEvent + 1602
26 com.apple.AppKit 0x9931bad0 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
27 com.apple.AppKit 0x9930e35c -[NSApplication run] + 727
28 com.apple.AppKit 0x992f71f8 NSApplicationMain + 1165
29 com.sketchup.SketchUp 0x000028d5 start + 53
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x920b9992 kevent64 + 10
1 libdispatch.dylib 0x9081e8bd _dispatch_mgr_invoke + 238
2 libdispatch.dylib 0x9081e556 _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x920b3f7a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x920b316c mach_msg + 68
2 com.apple.CoreFoundation 0x9007ef69 __CFRunLoopServiceMachPort + 169
3 com.apple.CoreFoundation 0x9007e541 __CFRunLoopRun + 1393
4 com.apple.CoreFoundation 0x9007dd5a CFRunLoopRunSpecific + 394
5 com.apple.CoreFoundation 0x9007dbbb CFRunLoopRunInMode + 123
6 com.apple.AppKit 0x994c5f18 _NSEventThread + 283
7 libsystem_pthread.dylib 0x946a95fb _pthread_body + 144
8 libsystem_pthread.dylib 0x946a9485 _pthread_start + 130
9 libsystem_pthread.dylib 0x946aecf2 thread_start + 34
Thread 3:: CVDisplayLink
0 libsystem_kernel.dylib 0x920b87ca __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x946abd1d _pthread_cond_wait + 728
2 libsystem_pthread.dylib 0x946adbd9 pthread_cond_wait$UNIX2003 + 71
3 com.apple.CoreVideo 0x90ec4540 CVDisplayLink::runIOThread() + 936
4 com.apple.CoreVideo 0x90ec4180 startIOThread(void*) + 159
5 libsystem_pthread.dylib 0x946a95fb _pthread_body + 144
6 libsystem_pthread.dylib 0x946a9485 _pthread_start + 130
7 libsystem_pthread.dylib 0x946aecf2 thread_start + 34
Thread 4:: com.apple.NSURLConnectionLoader
6 com.apple.Foundation 0x910360b5 +[NSURLConnection(Loader) _resourceLoadLoop:] + 381
7 com.apple.Foundation 0x91035f2e -[NSThread main] + 45
8 com.apple.Foundation 0x91035e86 __NSThread__main__ + 1426
9 libsystem_pthread.dylib 0x946a95fb _pthread_body + 144
10 libsystem_pthread.dylib 0x946a9485 _pthread_start + 130
11 libsystem_pthread.dylib 0x946aecf2 thread_start + 34
Thread 5:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x920b8ace __select + 10
1 com.apple.CoreFoundation 0x900cedc6 __CFSocketManager + 1158
2 libsystem_pthread.dylib 0x946a95fb _pthread_body + 144
3 libsystem_pthread.dylib 0x946a9485 _pthread_start + 130
4 libsystem_pthread.dylib 0x946aecf2 thread_start + 34
Thread 6:: JavaScriptCore::BlockFree
3 com.apple.JavaScriptCore 0x9bb289c4 JSC::BlockAllocator::blockFreeingThreadMain() + 276
4 com.apple.JavaScriptCore 0x9bb1fd7c WTF::threadEntryPoint(void*) + 76
5 com.apple.JavaScriptCore 0x9bb1fd10 WTF::wtfThreadEntryPoint(void*) + 16
6 libsystem_pthread.dylib 0x946a95fb _pthread_body + 144
7 libsystem_pthread.dylib 0x946a9485 _pthread_start + 130
8 libsystem_pthread.dylib 0x946aecf2 thread_start + 34
Thread 7:: JavaScriptCore::Marking
3 com.apple.JavaScriptCore 0x9bb293cb JSC::GCThread::waitForNextPhase() + 123
4 com.apple.JavaScriptCore 0x9bb29258 JSC::GCThread::gcThreadMain() + 88
5 com.apple.JavaScriptCore 0x9bb1fd7c WTF::threadEntryPoint(void*) + 76
6 com.apple.JavaScriptCore 0x9bb1fd10 WTF::wtfThreadEntryPoint(void*) + 16
Thread 8:: JavaScriptCore::Marking
Thread 9:: JavaScriptCore::Marking
Thread 10:: JavaScriptCore::Marking
Thread 11:: JavaScriptCore::Marking
Thread 12:: JavaScriptCore::Marking
Thread 13:
6 com.apple.HIToolbox 0x90398e2d RunCurrentEventLoopInMode + 259
7 com.apple.HIToolbox 0x9052f9e0 RunCurrentEventLoop + 60
8 com.3dconnexion.3DxSketchUp 0x2ab1946a tdxThread(void*) + 570
9 com.apple.CoreServices.CarbonCore 0x947cb56e PrivateMPEntryPoint + 68
10 libsystem_pthread.dylib 0x946a95fb _pthread_body + 144
11 libsystem_pthread.dylib 0x946a9485 _pthread_start + 130
12 libsystem_pthread.dylib 0x946aecf2 thread_start + 34
Thread 14:
0 libsystem_kernel.dylib 0x920b9046 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x946aadcf _pthread_wqthread + 372
2 libsystem_pthread.dylib 0x946aecce start_wqthread + 30
Thread 15:
Thread 16:
0 libsystem_kernel.dylib 0x920b8aea __select_nocancel + 10
1 libsystem_kernel.dylib 0x920b6884 select + 92
2 KerkytheaEcho.dylib 0x34411070 FX::fxsleep(unsigned int) + 94
3 KerkytheaEcho.dylib 0x342986cb CThreadedRayTracer::RayTrace(Thea::RenderTarget&) + 1053
4 KerkytheaEcho.dylib 0x342e5476 Thea::Kernel::RenderImage(Thea::RenderTarget&) + 138
5 KerkytheaEcho.dylib 0x3418d62b SDKRayTraceThread::run() + 169
6 KerkytheaEcho.dylib 0x344107a5 FX::FXThread::function(void*) + 79
Thread 17:
0 KerkytheaEcho.dylib 0x3451be34 x::TabelionIrradianceCaching<float>::addIrradiance(x::TabelionIrradianceCaching<float>::SearchSample&) const + 264
1 KerkytheaEcho.dylib 0x3451c0d0 x::TabelionIrradianceCaching<float>::addIrradiance(x::TabelionIrradianceCaching<float>::SearchSample&) const + 932
2 KerkytheaEcho.dylib 0x3451c0d0 x::TabelionIrradianceCaching<float>::addIrradiance(x::TabelionIrradianceCaching<float>::SearchSample&) const + 932
3 KerkytheaEcho.dylib 0x3451c0d0 x::TabelionIrradianceCaching<float>::addIrradiance(x::TabelionIrradianceCaching<float>::SearchSample&) const + 932
4 KerkytheaEcho.dylib 0x3451c0d0 x::TabelionIrradianceCaching<float>::addIrradiance(x::TabelionIrradianceCaching<float>::SearchSample&) const + 932
5 KerkytheaEcho.dylib 0x3451c0d0 x::TabelionIrradianceCaching<float>::addIrradiance(x::TabelionIrradianceCaching<float>::SearchSample&) const + 932
6 KerkytheaEcho.dylib 0x3451c0d0 x::TabelionIrradianceCaching<float>::addIrradiance(x::TabelionIrradianceCaching<float>::SearchSample&) const + 932
7 KerkytheaEcho.dylib 0x3451c0d0 x::TabelionIrradianceCaching<float>::addIrradiance(x::TabelionIrradianceCaching<float>::SearchSample&) const + 932
8 KerkytheaEcho.dylib 0x3451f74f x::TabelionIrradianceCaching<float>::askIrradiance(x::transform<float> const&, float&, float&, float&, float) const + 239
9 KerkytheaEcho.dylib 0x34520249 Thea::FinalGathering::AskIrradiance(x::transform<float> const&, bool) + 485
10 KerkytheaEcho.dylib 0x342d46e2 Thea::FinalGathering::AskIrradiance(x::point<float> const&, Thea::Intersection const&, bool) + 286
11 KerkytheaEcho.dylib 0x341b981a CDiffuseInterreflection::AskRadiance(x::point<float> const&, Thea::Intersection const&, x::rgb<float, x::colordummy<float> >&, Thea::IrradianceEstimator::Type, x::random<float>*, unsigned int) + 316
12 KerkytheaEcho.dylib 0x34503c66 CStandardRayTracer::EstimateIncomingDirectRadiance(x::material<float> const&, x::basicline<float> const&, Thea::Intersection const&, Thea::Environment const&, x::material<float>::Lobe) + 186
13 KerkytheaEcho.dylib 0x34286e93 CStandardRayTracer::EstimateIncomingRadianceBranch(x::material<float> const&, x::vector<float> const&, Thea::Intersection const&, Thea::Environment const&, x::rgb<float, x::colordummy<float> > const&, unsigned int, unsigned int, unsigned int, x::material<float>::Lobe, CStandardRayTracer::FragmentAntialias*) + 2223
14 KerkytheaEcho.dylib 0x34504f14 CStandardRayTracer::EstimateIncomingRadiance(x::basicline<float> const&, Thea::Environment const&, CStandardRayTracer::FragmentAntialias*, float) + 1980
15 KerkytheaEcho.dylib 0x3428791b CStandardRayTracer::EstimateIncomingRadianceDOF(unsigned int, float, float, Thea::Camera const&, Thea::Environment const&, CStandardRayTracer::FragmentAntialias*) + 287
16 KerkytheaEcho.dylib 0x3427b4a6 Antialiasing3x3::AntialiasPixel(unsigned int, unsigned int) + 262
17 KerkytheaEcho.dylib 0x34287e97 CStandardRayTracer::AntialiasWindow(x::matrix<x::rgb<float, x::colordummy<float> > >&, unsigned int, unsigned int, unsigned int, unsigned int, bool) + 1047
18 KerkytheaEcho.dylib 0x3429012d CStandardRayTracer::RayTraceBucket(Thea::RenderTarget&, unsigned int, unsigned int, unsigned int, unsigned int, unsigned int) + 697
19 KerkytheaEcho.dylib 0x3429a07d MyRayTraceThread::run() + 2373
20 KerkytheaEcho.dylib 0x344107a5 FX::FXThread::function(void*) + 79
21 libsystem_pthread.dylib 0x946a95fb _pthread_body + 144
22 libsystem_pthread.dylib 0x946a9485 _pthread_start + 130
23 libsystem_pthread.dylib 0x946aecf2 thread_start + 34
Thread 18:
0 KerkytheaEcho.dylib 0x3451be7c x::TabelionIrradianceCaching<float>::addIrradiance(x::TabelionIrradianceCaching<float>::SearchSample&) const + 336
7 KerkytheaEcho.dylib 0x3451f74f x::TabelionIrradianceCaching<float>::askIrradiance(x::transform<float> const&, float&, float&, float&, float) const + 239
8 KerkytheaEcho.dylib 0x34520249 Thea::FinalGathering::AskIrradiance(x::transform<float> const&, bool) + 485
9 KerkytheaEcho.dylib 0x342d46e2 Thea::FinalGathering::AskIrradiance(x::point<float> const&, Thea::Intersection const&, bool) + 286
10 KerkytheaEcho.dylib 0x341b981a CDiffuseInterreflection::AskRadiance(x::point<float> const&, Thea::Intersection const&, x::rgb<float, x::colordummy<float> >&, Thea::IrradianceEstimator::Type, x::random<float>*, unsigned int) + 316
11 KerkytheaEcho.dylib 0x34503c66 CStandardRayTracer::EstimateIncomingDirectRadiance(x::material<float> const&, x::basicline<float> const&, Thea::Intersection const&, Thea::Environment const&, x::material<float>::Lobe) + 186
12 KerkytheaEcho.dylib 0x34286e93 CStandardRayTracer::EstimateIncomingRadianceBranch(x::material<float> const&, x::vector<float> const&, Thea::Intersection const&, Thea::Environment const&, x::rgb<float, x::colordummy<float> > const&, unsigned int, unsigned int, unsigned int, x::material<float>::Lobe, CStandardRayTracer::FragmentAntialias*) + 2223
13 KerkytheaEcho.dylib 0x34287172 CStandardRayTracer::EstimateIncomingRadianceBranch(x::material<float> const&, x::vector<float> const&, Thea::Intersection const&, Thea::Environment const&, x::rgb<float, x::colordummy<float> > const&, unsigned int, unsigned int, unsigned int, x::material<float>::Lobe, CStandardRayTracer::FragmentAntialias*) + 2958
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x33be940c ecx: 0xbfffb5bc edx: 0x920b8952
edi: 0xa08521a8 esi: 0x00000006 ebp: 0xbfffb5d8 esp: 0xbfffb5bc
ss: 0x00000023 efl: 0x00000206 eip: 0x920b8952 cs: 0x0000000b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 0
Error Code: 0x00080148
Trap Number: 132
Binary Images:
0x1000 - 0x769ffb +com.sketchup.SketchUp (13.0 - 13.0.4811) <9F4F46F3-6082-361C-A9F4-237288E6ED01> /Applications/SketchUp 2013/SketchUp.app/Contents/MacOS/SketchUp
0xa37000 - 0xa39fff +com.bugsplatsoftware.bugsplatframework (1.0) <AAB09F90-2880-36FC-AA52-B1EFBC9DC207> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/BugSplat.framework/Versions/A/BugSplat
0xa3f000 - 0xa44ff7 +libCommonPreferences.dylib (1) <F182E3D9-AD85-3ECC-9A1B-C7FD62CEEBEE> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCommonPreferences.dylib
0xa4f000 - 0x1231feb +libCommonVideo.dylib (1) <13B6892B-2233-3561-B5C5-2D1E838FAEB2> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCommonVideo.dylib
0x1855000 - 0x1881ff7 +libCommonGeometry.dylib (1) <99B311D8-A590-3068-9EBA-97F2C7597C55> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCommonGeometry.dylib
0x189c000 - 0x1abeff7 +libCommonImage.dylib (1) <2888FAF9-B8CB-3283-AEDF-0EE9A5A4148C> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCommonImage.dylib
0x1ae3000 - 0x1e14feb +libCommonGeoformats.dylib (1) <9D3B1F7D-C5F0-31CB-8727-E607A5F7DC3A> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCommonGeoformats.dylib
0x1ee1000 - 0x1ee3fff +libCommonGeoutils.dylib (1) <078A0984-C2B0-3430-856D-E7B871AEF7D1> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCommonGeoutils.dylib
0x1ee9000 - 0x1ef1ff3 +libCommonInternet.dylib (1) <0A1E58D1-ADC8-34CB-A2E7-D0265C09D67D> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCommonInternet.dylib
0x1efb000 - 0x1f15ff7 +libCommonUtils.dylib (1) <2793E63C-E689-3852-AE39-5BFCCA1D8550> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCommonUtils.dylib
0x1f2a000 - 0x1f4cff3 +libCommonWarehouseapi.dylib (1) <5CBB7A4F-7644-3F79-8C24-D9403BF11600> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCommonWarehouseapi.dylib
0x1f62000 - 0x1f78ff3 +libCommonZip.dylib (1) <2FFDEBA5-9E83-3761-BB4D-EC2A0D51A219> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCommonZip.dylib
0x1f82000 - 0x3080fe7 +DWGDirect (0) <B103FA4C-700D-1A02-F34A-59630B2D93E2> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/DWGDirect.framework/Versions/A/DWGDirect
0x37bb000 - 0x387bfcb +com.google.rubyframework (1.0) /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/A/Ruby
0x38ab000 - 0x38b4ffb +com.sketchup.WebDialog (1.0) <B4177ADE-4A49-3933-9356-7C9BB827B1EE> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/WebDialog.framework/Versions/A/WebDialog
0x38bc000 - 0x38cbfff +libAlchemyExt.dylib (1) <0FD1611F-71D1-3F56-85A3-9ADAE5C9A02E> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libAlchemyExt.dylib
0x38e4000 - 0x3926ff3 +libIGAttrs.dylib (0) <04340FB5-3ED1-30EC-91AF-DC802541ADCE> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libIGAttrs.dylib
0x398e000 - 0x3a14ff3 +libIGCore.dylib (0) <8EA56D42-069E-3744-8F7B-FE2B8F14A742> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libIGCore.dylib
0x3a9d000 - 0x3d45ff7 +libIGGfx.dylib (0) <0E2F8EB6-643A-350F-8C59-51448488E589> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libIGGfx.dylib
0x3e12000 - 0x3e3affb +libIGMath.dylib (0) <7BAFEB7E-59FF-3C2F-BDD2-E4B93A3A36FF> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libIGMath.dylib
0x3e68000 - 0x3f06ff7 +libIGSg.dylib (0) <9D63ACB8-1AB1-3C7C-A638-31E98A156238> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libIGSg.dylib
0x3fa4000 - 0x3fb6ff7 +libIGUtils.dylib (0) <3C3C0947-45E6-3226-8CE9-290AA96411FC> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libIGUtils.dylib
0x3fd8000 - 0x3ff3ff3 +com.sketchup.ALAppKit (1.0) <33D3B636-C61D-3043-937D-8E6D5F92A5BD> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/ALAppKit.framework/Versions/A/ALAppKit
0x4000000 - 0x4000fff com.apple.VideoDecodeAcceleration (1.1 - 8) <3924450C-B496-37BC-91D6-C20F368B63F9> /System/Library/Frameworks/VideoDecodeAcceleration.framework/Versions/A/VideoDecodeAcceleration
0x42cf000 - 0x42daffa com.apple.CommerceCore (1.0 - 42) <FB799100-F7E7-3515-AB46-C09E1A85C3E6> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x8e76000 - 0x8e9bff9 com.apple.framework.familycontrols (4.1 - 410) <1C51C102-191C-3EE5-BC56-24B7DE55B885> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x15b64000 - 0x15b64ffb +cl_kernels (???) <9EC20E7B-1C1C-4FB5-99A3-579AD01BF710> cl_kernels
0x18d24000 - 0x18d24ff3 +cl_kernels (???) <33AE7A35-1ED9-41B0-999A-E110446966E5> cl_kernels
0x1b612000 - 0x1b6f8ff7 unorm8_rgba.dylib (2.3.58) <79BA72EB-A4D0-3780-A062-EBDAC1FCB60C> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
0x1b724000 - 0x1b80fff7 unorm8_bgra.dylib (2.3.58) <B9AFBEF4-17E8-3913-9287-F7A50BC8F963> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x1bf2a000 - 0x1bf2bff3 +cl_kernels (???) <D3AA343C-9FAD-4373-9A27-77FA25019089> cl_kernels
0x1bf31000 - 0x1bf31ff5 +cl_kernels (???) <369AFC80-05BC-4AFD-9642-1FEF9930A5F9> cl_kernels
0x1bf33000 - 0x1bf34ffd +cl_kernels (???) <C91D06FE-CA0A-46D4-AFA9-962DF25B668C> cl_kernels
0x1bf53000 - 0x1bf53ffd +cl_kernels (???) <1DF30DC5-8502-4145-8059-BABD66790C7F> cl_kernels
0x1bf58000 - 0x1bf59fff +cl_kernels (???) <D06F1188-3252-4F4D-A1C2-185516256F21> cl_kernels
0x1bf63000 - 0x1bf64ff3 +cl_kernels (???) <D82E482E-0F56-4368-B720-F4E56E02E972> cl_kernels
0x1c2f2000 - 0x1c2f3ff1 +cl_kernels (???) <25DA7675-398A-45BC-8F96-CDB4AFF19243> cl_kernels
0x1e060000 - 0x1e061ff7 +cl_kernels (???) <645C7203-61E0-4FAE-9A98-125C90698530> cl_kernels
0x1ef99000 - 0x1ef9aff7 +cl_kernels (???) <CBB61CD6-B961-47AA-B03A-988862AAA56F> cl_kernels
0x1ef9e000 - 0x1ef9effd +cl_kernels (???) <E688494E-BDB3-4119-94C9-C1392305E872> cl_kernels
0x1efa7000 - 0x1efa8ff5 +cl_kernels (???) <AD96CD27-1142-4615-BCBA-7F55F955135F> cl_kernels
0x1efaa000 - 0x1efaeff9 libgermantok.dylib (14) <020C30B6-3B7C-3760-A784-27A65037A21E> /usr/lib/libgermantok.dylib
0x21c4c000 - 0x21c4cffd +cl_kernels (???) <9100AB6D-9B50-4D61-81D0-B79F0953F095> cl_kernels
0x21d07000 - 0x21df2ff7 unorm8_argb.dylib (2.3.58) <A244D8F8-4E1B-3700-A4E8-473D6A36F629> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_argb.dylib
0x25676000 - 0x2567affd libFontRegistryUI.dylib (127) <C207DFF5-0C48-3831-B9F1-2363D9A7A365> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0x25d8c000 - 0x25d92ff7 +net.wafflesoftware.hexcolorpicker (1.6.1) <D3AAA31A-113E-51D4-F384-6B33BB5B86C3> /Users/USER/Library/ColorPickers/HexColorPicker.colorPicker/Contents/MacOS/HexColorPicker
0x2952b000 - 0x2952cff8 ATSHI.dylib (363.1) <1230337B-D921-3F25-84E9-CA7E8EACBA96> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x2a0f8000 - 0x2a0f9ff7 +SketchUp (0.0.1d1) <EF6D82C2-C15B-39C8-80E7-9FFA3417562E> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/SketchUp.framework/Versions/A/SketchUp
0x2a190000 - 0x2a1b9ff3 +3dsExporter (3DS Exporter Version 6.0 - 0.0.1d1) <BAEED283-3D92-3C99-AB02-3C58B1AF73FC> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/3dsExporter.plugin/Contents/MacOS/3dsExporter
0x2a1d5000 - 0x2a1e6ff7 +lib3ds.dylib (1) <C49CAB13-F949-8713-16C5-8B594835296F> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/3dsExporter.plugin/Contents/Frameworks/lib3ds.dylib
0x2a1ed000 - 0x2a1f6ff7 +com.atlast.importers.3ds (1.0) <B2E33012-C3E0-30D4-9DBF-7A068AF5530D> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/3DSImporter.plugin/Contents/MacOS/3DSImporter
0x2a248000 - 0x2a259ff7 +lib3ds.dylib (1) <C49CAB13-F949-8713-16C5-8B594835296F> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/3DSImporter.plugin/Contents/Frameworks/lib3ds.dylib
0x2a260000 - 0x2a268ff3 +DaeExporter (0.0.1d1) <27F0507A-F505-3030-9B3D-6B8A14AC3E2A> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/DaeExporter.plugin/Contents/MacOS/DaeExporter
0x2a272000 - 0x2a278ff7 +DaeImporter (0.0.1d1) <4AEF7778-EE88-34DF-A09E-7B572DA5EC56> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/DaeImporter.plugin/Contents/MacOS/DaeImporter
0x2a282000 - 0x2a299ff7 +com.atlast.demimporter (1.0) <8F52B4B8-D1D8-3833-8D27-E7175CBBDF3A> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/DEMImporter.plugin/Contents/MacOS/DEMImporter
0x2a400000 - 0x2a5cefff +slapi (1) <EEAA4AF5-B832-3E96-B92E-3D08E22FD1AF> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/slapi.framework/Versions/A/slapi
0x2a6a6000 - 0x2a6b2ff7 +KmzExporter (0.0.1d1) <B1A665A4-7D7C-347D-97BA-A60152F569B1> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/KmzExporter.plugin/Contents/MacOS/KmzExporter
0x2a6be000 - 0x2a6c6ffb +KmzImporter (0.0.1d1) <03AD008F-974E-3548-89AB-8F02029CB59D> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/KmzImporter.plugin/Contents/MacOS/KmzImporter
0x2a6d0000 - 0x2a6f4ff7 +ObjExporter (OBJ Exporter Version 6.0 - 0.0.1d1) <9FBA09D9-22BC-3241-96DF-15C622E675DB> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/ObjExporter.plugin/Contents/MacOS/ObjExporter
0x2a70d000 - 0x2a748ff7 +Skp2Acad (0.1) <3DB744BF-413E-3839-A1E8-7B57F97682B0> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/Skp2Acad.plugin/Contents/MacOS/Skp2Acad
0x2a766000 - 0x2a79bfff +com.atlast.Skp2AcadHlr (1.0) <6E3119AF-1070-3234-9E88-9C707D315945> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/Skp2AcadHlr.plugin/Contents/MacOS/Skp2AcadHlr
0x2a7b5000 - 0x2a7ebff7 +com.atlast.Skp2AcadSection (1.0) <B89B2C34-1C91-3BEA-BB2E-18C84F5E7160> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/Skp2AcadSection.plugin/Contents/MacOS/Skp2AcadSection
0x2a805000 - 0x2a82dfff +VRMLExporter (VRML Exporter Version 6.0 - 0.0.1d1) <F4C5FE01-9887-34FE-9C95-8B46911CA8BC> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/VRMLExporter.plugin/Contents/MacOS/VRMLExporter
0x2a847000 - 0x2a873ffb +XsiExporter (XSI Exporter Version 6.0 - 0.0.1d1) <E9AD2E0B-D72A-3CB0-896E-0DE45786CED3> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/XsiExporter.plugin/Contents/MacOS/XsiExporter
0x2a890000 - 0x2a891ffd com.apple.textencoding.unicode (2.6 - 2.6) <27946D57-CEFB-3EF1-B124-4A39D2621738> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x2a9fc000 - 0x2aaa6ff7 libruby.1.dylib (4) <959F5EB8-3111-3E0E-8F8D-334459B96C81> /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/libruby.1.dylib
0x2ab06000 - 0x2ab22ff3 +com.3dconnexion.3DxSketchUp (3.2.0 - 3.2.0.9051) <63DD5CE9-528D-62FD-79B6-2C6951173693> /Library/Application Support/SketchUp 2013/*/3DxSketchUp.bundle.plugin/Contents/MacOS/3DxSketchUp.bundle
0x30f61000 - 0x31194fff +libCollada.dylib (1) <E0B3B0C6-35CA-3B8B-A593-90E077520BF9> /Applications/SketchUp 2013/SketchUp.app/Contents/Frameworks/libCollada.dylib
0x31aad000 - 0x32190fff +FbxExporter (FBX Exporter Version 8.0 - ???) <2F7A3404-4AFB-39E6-8B67-9D7F633AEC16> /Applications/SketchUp 2013/SketchUp.app/Contents/PlugIns/FbxExporter.plugin/Contents/MacOS/FbxExporter
0x32f00000 - 0x32fb0fff ColorSyncDeprecated.dylib (426) <2ACB020C-75FC-3817-B624-BE3648957FFB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x33800000 - 0x3392cffb +TwilightLib.bundle (???) <B547CDE4-A4C0-E4FD-C175-3F420F31907B> /Users/USER/Library/Application Support/SketchUp 2013/*/TwilightLib.bundle
0x33937000 - 0x33dabfef +TwilightWidgets.so (???) <080A8A77-15A6-EE29-B6AF-DBDE67F2537E> /Users/USER/Library/Application Support/SketchUp 2013/*/TwilightWidgets.so
0x33e16000 - 0x34081ff7 +libfreeimage-3.15.2.dylib (0) <7611703D-C507-C3D9-8893-A78EF9461804> /Users/USER/Library/Application Support/SketchUp 2013/*/libfreeimage-3.15.2.dylib
0x3414b000 - 0x345f8ff7 +KerkytheaEcho.dylib (1) /Users/USER/Library/Application Support/SketchUp 2013/*/KerkytheaEcho.dylib
0x35cf0000 - 0x35cf4fff com.apple.CommonCocoaPanels (4.0 - 16) <31DBF3A0-4456-3A25-97AB-1C85C68D1A9A> /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
0x368f5000 - 0x368fcff8 com.apple.AppleGVAHW.component (1.2 - 1) <DEEECAF7-BFB9-3BD0-B970-3902C8BAF100> /System/Library/QuickTime/AppleGVAHW.component/Contents/MacOS/AppleGVAHW
0x38914000 - 0x38926ff7 com.apple.FCP Uncompressed 422.component (2.0.2 - 6337.11) <658180EB-E040-34E4-BCB7-1DD0D6AAD2C4> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0x3ffd7000 - 0x3fff8fff com.apple.IMXCodec (2.0.2 - 6337.11) <FCD6FEAA-8C30-3D27-8C4D-5F07B8E16200> /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0x40000000 - 0x4045eff7 com.apple.driver.AppleIntelHD5000GraphicsGLDriver (8.20.26 - 8.2.0) <EECE9592-8617-33A9-B913-33E5A274F342> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
0x40f74000 - 0x40fa6ff7 com.apple.AppleIntermediateCodec (2.0.2 - 6337.11) <9EEB350C-D625-38C9-BB5B-12E020FE366E> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x4160c000 - 0x41644ff7 com.apple.QuickTimeFireWireDV.component (7.7.3 - 2826) <8DDDAD6E-E7BD-3EB6-AE48-324CCC2ABD16> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x41ce6000 - 0x41d21fab com.apple.AppleAVCIntraCodec (2.1.2 - 6344.11) <80694757-7D85-30C1-9879-D3A9B5B74393> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
0x42455000 - 0x4246eff2 com.apple.applepixletvideo (1.2.31 - 1.2d31) <AE02E08C-891E-3898-8E42-C7C83E3EF08E> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x42cf7000 - 0x42d3affb com.apple.DVCPROHDCodec (2.0.2 - 6337.11) <24E2A5DA-B7FC-3B84-BEEE-DEB9CC77C8C8> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
0x436a2000 - 0x437a7fe3 com.apple.AppleProResCodec (3.0.4 - 6305.11) <BBF33C8A-86CF-3779-AE1E-C95C470AB9A0> /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
0x437b4000 - 0x437f8ff7 com.apple.AppleVAH264HW.component (3.0 - 3.0) <501A8BA2-2B49-3B6B-B2C5-01BFE8477FA7> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0x438bb000 - 0x4396fff7 com.apple.AppleGVAFramework (7.1.0 - 7.1.0) <43992B27-475F-3E5E-B68F-32A5BF21238B> /System/Library/PrivateFrameworks/AppleGVA.framework/Versions/A/AppleGVA
0x4397f000 - 0x43a06fff com.apple.AppleHDVCodec (2.0.4 - 6308.11) <33ED79FA-B812-37CA-BEF2-5793F9AA1E76> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
0x48000000 - 0x488d7fff com.apple.GeForceGLDriver (8.20.15 - 8.2.0) <6F87AD6E-8552-3680-9D60-8F9865B636AA> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x8fef6000 - 0x8ff28417 dyld (239.3) <4B280BB1-55F8-313F-86A6-8ADD644ED69E> /usr/lib/dyld
0x90008000 - 0x9020aff7 com.apple.CoreFoundation (6.9 - 855.11) <21BA3E03-EA00-3AC4-8B31-806779114FE8> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9020b000 - 0x90216ff6 com.apple.NetAuth (5.0 - 5.0) <3B2E9615-EE12-38FC-BDCF-09529FF9464B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x90217000 - 0x90229fff libsystem_asl.dylib (217.1.4) <F4B8D4CC-71BC-3C45-8669-91747B456739> /usr/lib/system/libsystem_asl.dylib
0x9022a000 - 0x90279fff com.apple.opencl (2.3.58 - 2.3.58) <82A383B9-EFE6-38D0-8465-CFB8F9367834> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9027a000 - 0x90282fee libcldcpuengine.dylib (2.3.58) <D68C7948-9A1F-3505-9B32-C007AD6A793D> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x90283000 - 0x902ecfff com.apple.SystemConfiguration (1.13 - 1.13) <542075CD-9085-3F30-B84B-DD0277D6A40E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x902ed000 - 0x90316ff5 com.apple.shortcut (2.6 - 2.6) <1474DC02-7BAE-3F68-B052-F207BE0D517F> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x90317000 - 0x9036cff3 com.apple.ImageCaptureCore (5.0 - 5.0) <1C9A2866-6FA8-3FBD-B471-DA0D27F960CE> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x9036d000 - 0x906e2ff9 com.apple.HIToolbox (2.1 - 695) <BF1E4EFC-EE3A-3735-81C9-EF3C8A613BB9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x906e3000 - 0x9081aff3 com.apple.desktopservices (1.8 - 1.8) <1CA936E2-C5DB-32BF-AFD0-E8FF97A462A5> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9081b000 - 0x90833ffd libdispatch.dylib (339.1.9) <4A985218-0898-3554-8DB1-BCA0B676B9A6> /usr/lib/system/libdispatch.dylib
0x90834000 - 0x908ccff7 com.apple.Metadata (10.7.0 - 800.12) <0AE4CD6B-FDFC-31ED-9F2C-FE870155CAF9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x908cd000 - 0x90922ff2 com.apple.Suggestions (3.0 - 137.1) <2093AC55-3E06-3822-8387-938587F677C2> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x90923000 - 0x90935fff libbsm.0.dylib (33) <1BE92DB5-0D2F-3BB5-BCC6-8A71EF2A3450> /usr/lib/libbsm.0.dylib
0x90936000 - 0x90942ff7 com.apple.OpenDirectory (10.9 - 173.1.1) <2AA24814-2DC6-3E28-B71B-186B686F0F19> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x90943000 - 0x90974ffd com.apple.GSS (4.0 - 2.0) <FB94C6FD-E9AE-3B26-9242-E3298EF1BA69> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x90975000 - 0x90985ff5 com.apple.LangAnalysis (1.7.0 - 1.7.0) <8106E9A2-F2A7-392C-
Re: OS X Mavericks
Posted: Mon Dec 23, 2013 9:47 pm
by Cody
part II
B404-E88A20843F0C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x90986000 - 0x909e4fff com.apple.ViewBridge (1.0 - 46) <015D1716-B19C-3E77-886E-DC60791348FC> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x909e5000 - 0x90a0dfff libsystem_info.dylib (449.1.3) <3FE52670-FFEE-3D04-ADE7-EA69BC00B066> /usr/lib/system/libsystem_info.dylib
0x90a0e000 - 0x90a78ff7 com.apple.framework.CoreWiFi (2.0 - 200.21.1) <4B96CA5D-2670-3B66-B648-3F2B5BAE5238> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x90a79000 - 0x90c25ff1 com.apple.QuartzCore (1.8 - 332.0) <C8467E02-1AC0-333E-890E-9AAD65FAEC0E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x90c26000 - 0x90d53ff9 com.apple.avfoundation (2.0 - 651.12) <46DF19FF-7A29-33CE-9D80-E2CEE163C2C6> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x90d54000 - 0x90d5aff7 com.apple.AOSNotification (1.7.0 - 760.3) <6F809FD3-4DE6-32C4-9E8A-5CBCAE3A73C9> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification
0x90d5b000 - 0x90e72ffb com.apple.WebKit (9537 - 9537.71) <2D6ADE14-A373-3DF8-8AC4-9A7F4DDE4195> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x90ec2000 - 0x90ee9fff com.apple.CoreVideo (1.8 - 117.2) <4FDBE865-4A94-39B7-B9F4-44055EC988C3> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x90eea000 - 0x90ef4fff com.apple.bsd.ServiceManagement (2.0 - 2.0) <907F726B-BA7D-360C-8E46-02DB99DD903A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x90ef5000 - 0x90f6aff1 com.apple.ApplicationServices.ATS (360 - 363.1) <5C9BC698-0CC1-3F6A-9F9D-BCC3A9C3D6DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90f6b000 - 0x90f88ffb libresolv.9.dylib (54) <3EC12A7F-6BA1-3976-9F1F-6A4B76303028> /usr/lib/libresolv.9.dylib
0x90f89000 - 0x90fc8ff5 com.apple.ids (10.0 - 1000) <AEDCAD16-6626-3A0B-A9BE-3FC8A47CEB52> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0x90fc9000 - 0x912f4ff6 com.apple.Foundation (6.9 - 1056) <B30A8E0D-B36F-37D9-AA80-E4E02D6EE192> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x912f5000 - 0x91327ffb com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <1D512F2A-695A-3D82-A6B3-1DDC88865BE5> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x91328000 - 0x915a4ff7 com.apple.QuickTime (7.7.3 - 2826) <25F10D75-66D3-34F0-8C50-2219A24680F2> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x915a5000 - 0x915aefff com.apple.AppleSRP (5.0 - 1) <6B946F4B-7DC4-3E82-BF2C-BE0930E3CF47> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x915af000 - 0x915bafff libGPUSupportMercury.dylib (9.3.1) <75FF69D5-0D1F-3495-9EBE-85F0BF687AC6> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x915bb000 - 0x91624fff com.apple.datadetectorscore (5.0 - 354.0) <CEE08580-8FFC-3241-9E7D-851908179FB2> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x91625000 - 0x91625ffd libOpenScriptingUtil.dylib (157) <4D06E8ED-D312-34EA-A448-DFF45ADC3CE5> /usr/lib/libOpenScriptingUtil.dylib
0x91626000 - 0x91628fff com.apple.securityhi (9.0 - 55005) <51765C73-80D1-33E3-9589-3E88380CE007> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x91629000 - 0x9163fff9 com.apple.aps.framework (4.0 - 4.0) <B3D5B83C-4DDF-3E8E-A701-7931AE6FAF65> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x91640000 - 0x91648ff7 libCGCMS.A.dylib (599.7) <A7404924-9A2B-3324-A934-BD08953E7098> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x91649000 - 0x9165dff9 com.apple.MultitouchSupport.framework (245.13 - 245.13) <6860A0D0-3654-3B02-B2E9-C4D2637167B8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x9165e000 - 0x916afffb com.apple.CoreMedia (1.0 - 1273.35) <6BEDE306-DCAA-3D1E-AED4-6FC2A8CEF1C7> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x916b0000 - 0x91773ff1 com.apple.CoreText (352.0 - 367.15) <8C486246-B12A-39E1-9B35-DE9451FDCF4B> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x91774000 - 0x917b1ffb libGLImage.dylib (9.3.1) <26AB4352-1F99-3170-B5E0-459F561233D6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x917b2000 - 0x91a17ff7 com.apple.AddressBook.framework (8.0 - 1365) <FB07EEE9-C17C-3BE3-A425-18395522F8C6> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x91a18000 - 0x91a1cffa libGIF.dylib (1038) <1108B78D-2B39-3823-8FF8-6A9FDC31AC4E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91a1d000 - 0x91f8afff com.apple.QuartzComposer (5.1 - 316) <69FAED0D-0474-330F-A953-B1134C4C3119> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x91f8b000 - 0x91f8dfff libsystem_configuration.dylib (596.12) <DE9038BB-0403-3263-885F-D949F8FBAFE7> /usr/lib/system/libsystem_configuration.dylib
0x91f8e000 - 0x91fcaff4 com.apple.RemoteViewServices (2.0 - 94) <C08AC054-A318-3BC8-9634-510B39493C52> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x91fcb000 - 0x92021ff6 com.apple.ScalableUserInterface (1.0 - 1) <30203384-7230-356E-BF47-76307CD21148> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x92022000 - 0x92023ff7 com.apple.diagnosticlogcollection (10.0 - 1000) <CFF35D68-C835-3A74-BB0F-7344A4A7EFE6> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0x92024000 - 0x9205afff com.apple.IconServices (25 - 25.17) <05C87A32-3E0F-3EE7-8CE5-DB6463369FFA> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x9205b000 - 0x92069ff7 libz.1.dylib (53) <3D1E738F-D26C-3721-8E16-52473B560A8F> /usr/lib/libz.1.dylib
0x9206a000 - 0x92073fff com.apple.DiskArbitration (2.6 - 2.6) <53700F94-766F-3DA0-A9DF-DE2F8FF84CB3> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x92074000 - 0x920a0ff7 GLRendererFloat (9.3.1) <410EC313-AEF2-3DE1-B5DD-91B9EC587D2A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x920a1000 - 0x920beff4 libsystem_kernel.dylib (2422.75.4) <1FB471BD-92E5-314E-9C2B-154B117C06E8> /usr/lib/system/libsystem_kernel.dylib
0x920bf000 - 0x920c2ffa libCGXType.A.dylib (599.7) <2738FF52-4B47-31AD-B7E5-412F6AFACC2A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x920c3000 - 0x92a1dfeb com.apple.QuickTimeComponents.component (7.7.3 - 2826) <6B59F9E1-97DD-356F-A8DA-D8A9E2682F3E> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x92a1e000 - 0x92a1ffff libDiagnosticMessagesClient.dylib (100) <B936B1D4-90BB-395D-8EA9-E1237608E7D0> /usr/lib/libDiagnosticMessagesClient.dylib
0x92a20000 - 0x92a3eff5 com.apple.frameworks.preferencepanes (16.0 - 16.0) <B91EFB41-2157-38FE-BEE7-5CA9B021F8F7> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
0x92a3f000 - 0x92a47fff libsystem_dnssd.dylib (522.1.11) <AFF243AD-A0AF-3D7B-9E56-7B5BE81FC08C> /usr/lib/system/libsystem_dnssd.dylib
0x92a4a000 - 0x92b57fe4 com.apple.MediaControlSender (1.9 - 190.4) <364BDDB2-4280-3BAB-9CC4-697FDC303BCA> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x92b58000 - 0x92bacfff com.apple.AppleVAFramework (5.0.27 - 5.0.27) <DAA1002F-BEC8-37F3-9DB9-6B84F9A3819D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x92bad000 - 0x92bb1ffc com.apple.IOSurface (91 - 91) <B337413D-F2D6-3272-B74A-9E1392ED5756> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x92bb2000 - 0x92bc0ff3 com.apple.opengl (9.3.1 - 9.3.1) <8E5EB187-90D0-31BE-BF14-A1D9B402AA0C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x92bc1000 - 0x92d31fff com.apple.QTKit (7.7.3 - 2826) <C7D08428-ECD7-3E01-9E7A-A061CF3228F4> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x92d32000 - 0x92d3afff liblaunch.dylib (842.1.4) <3E946C2F-76B5-3980-BC07-30D78BBD3279> /usr/lib/system/liblaunch.dylib
0x92dd6000 - 0x93122ffb com.apple.MediaToolbox (1.0 - 1273.35) <E30AF97C-165A-37EA-9373-1A99188FA8B6> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x93123000 - 0x9312dff7 com.apple.DirectoryService.Framework (10.9 - 173.1.1) <D6735614-EF4B-389F-BF99-7D8416A504BA> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x9312e000 - 0x932beff0 GLEngine (9.3.1) <B8ACEE86-BEAE-3B9D-A780-74B674C58203> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x932bf000 - 0x933d1ffc libsqlite3.dylib (158) <A1CDF363-AB65-3D3F-B62C-171C01DEE337> /usr/lib/libsqlite3.dylib
0x933d2000 - 0x933dbffa com.apple.CommonAuth (4.0 - 2.0) <6CB82D57-3C55-39E5-9036-8047DF3E6F57> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x933dc000 - 0x93488ffb libvMisc.dylib (423.32) <43873EFF-FB43-3301-BEE8-F2C3A046D7A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x93489000 - 0x934cbfff libGLU.dylib (9.3.1) <F15F3C93-3B42-35AF-8417-B2F79FDE1B70> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x934cc000 - 0x9354cff7 com.apple.CoreServices.OSServices (600.4 - 600.4) <21FF2945-32B7-3ABD-ACBB-5533241999D8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x93715000 - 0x93809fff libFontParser.dylib (111.1) <D8F9B2A4-41A6-3407-8D80-13A841F97BE5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9380a000 - 0x9383bff4 com.apple.securityinterface (9.0 - 55047) <1E7B2EF1-5B7E-3F22-9A2C-B676E1092B4C> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x93873000 - 0x9389dff7 libsandbox.1.dylib (278.10) <DAC89956-5476-32E1-87CB-334731FAA372> /usr/lib/libsandbox.1.dylib
0x9389e000 - 0x9389efff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <DDAC0B59-F886-3AB1-98E8-C71FFF161CD4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9389f000 - 0x938bbff9 com.apple.Ubiquity (1.3 - 289) <64DEF1B4-F874-3DF2-9D58-ABBF0A15C5BB> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x938bc000 - 0x938c6ff2 com.apple.AppSandbox (3.0 - 1) <085C3B38-C7D8-3A62-AFC6-CEE27F93DFD1> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x938c7000 - 0x9391afff com.apple.htmlrendering (77 - 1.1.4) <E4988ECB-285F-3FC0-A8EC-48A1260A96C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x9391b000 - 0x93940ff7 com.apple.quartzfilters (1.8.0 - 1.7.0) <1B4BADEA-EEE1-33C4-8063-DAEBE3E6C9F3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x93941000 - 0x93a0eff7 com.apple.backup.framework (1.5 - 1.5) <C417419E-077B-3FC5-8530-02130271F42C> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x93a0f000 - 0x93a13ffe libCoreVMClient.dylib (58.1) <0EB8FFD7-AFED-3A63-810E-29629831D43D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x93a14000 - 0x93a67ff3 com.apple.CoreMediaIO (403.0 - 4555) <6BE07264-EBEC-3F85-BF09-FF350627D058> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x93a68000 - 0x93decff7 com.apple.FinderKit (1.2 - 1.2) <97A5857E-B4D8-3473-8A54-147F36E63EFA> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
0x93ded000 - 0x93e54ffc com.apple.framework.CoreWLAN (4.0 - 400.45.1) <8DADD7D2-AB98-34ED-8D6F-335338502CBE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x93e55000 - 0x93e92ff7 libauto.dylib (185.5) <CD008E66-4A0C-35F5-8D72-80D76A716A03> /usr/lib/libauto.dylib
0x93e93000 - 0x93ecbfff com.apple.LDAPFramework (2.4.28 - 194.5) <77DAAC92-8442-3BBD-9782-A7D48BC74BE3> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x93ecc000 - 0x93ecdfff com.apple.marco (10.0 - 1000) <B2919576-E00C-330C-8FBE-5349C8DC5AAD> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x93ece000 - 0x9404cff8 libGLProgrammability.dylib (9.3.1) <FBB14DDE-6A3B-30BB-81F9-088B3AF555A5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9404d000 - 0x94093fff libcurl.4.dylib (78) <533695E9-C1F9-368D-8F8E-9C35993791AF> /usr/lib/libcurl.4.dylib
0x94094000 - 0x9417fff4 com.apple.DiskImagesFramework (10.9 - 371.1) <FC13BD5A-0FB7-35D5-A8DF-0510CFA996FE> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x94180000 - 0x94182fff com.apple.SecCodeWrapper (3.0 - 1) <29ECC157-F444-31FE-99CC-A9289FF3AC8D> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x94183000 - 0x94548ff6 libLAPACK.dylib (1094.5) <E6286E68-3501-31AC-813E-75B3B3968011> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x94549000 - 0x9454dff7 libmacho.dylib (845) <AAB35F2B-B515-37CD-A637-A2E88DFE4080> /usr/lib/system/libmacho.dylib
0x9454e000 - 0x9454ffff libremovefile.dylib (33) <E6B6F0CD-1700-31DC-93DB-3D33EC85DA0C> /usr/lib/system/libremovefile.dylib
0x94550000 - 0x9465cfff com.apple.ImageIO.framework (3.3.0 - 1038) <4776FAFD-F80F-3BDE-A396-80D988BE8EC1> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9465d000 - 0x94689ff7 com.apple.DictionaryServices (1.2 - 208) <59E9F98C-9C58-34C6-9D78-1FD4649DCBC5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9468a000 - 0x9468bfff libSystem.B.dylib (1197.1.1) <5A9C548E-A852-35B3-B9AB-DF658EF75242> /usr/lib/libSystem.B.dylib
0x9468c000 - 0x946a7ff5 com.apple.openscripting (1.4 - 157) <5C161A52-8D2F-3D56-A988-05727BED7A59> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x946a8000 - 0x946afffb libsystem_pthread.dylib (53.1.4) <AD357A6E-6746-3FB2-B6F5-8101E9DE7671> /usr/lib/system/libsystem_pthread.dylib
0x946b0000 - 0x94712ff3 com.apple.imfoundation (10.0 - 1000) <13F1519A-2896-36D6-B6DD-75D3D6099E21> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x94713000 - 0x9473eff5 com.apple.ChunkingLibrary (2.0 - 155.1) <87D1076A-1EC8-3C26-93DB-E4AD394A45AF> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x9473f000 - 0x94a40ff7 com.apple.CoreServices.CarbonCore (1077.13 - 1077.13) <E8DCBCA8-99E5-3821-ADFC-B7CA151BEC74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x94a41000 - 0x94a5afff libAVFAudio.dylib (32.2) <F1189373-0635-32D5-BB0C-1261959DB675> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x94a5b000 - 0x94cdeff7 com.apple.RawCamera.bundle (5.01 - 718) <6CBC1883-D81D-3053-94CA-2AB4A460EE38> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x94d02000 - 0x94dd2fef libvDSP.dylib (423.32) <E2FA7230-A001-3F6B-9ACF-6998C51AD7DC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x94dd3000 - 0x95040ff6 com.apple.security (7.0 - 55471) <5FCF76B2-92C6-3404-87D3-91B3F6E203AA> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x95041000 - 0x95041fff com.apple.quartzframework (1.5 - 1.5) <95E39CD5-E118-323F-9F0F-EE605EC029CF> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x95042000 - 0x950d3fff com.apple.ColorSync (4.9.0 - 4.9.0) <10317959-1392-3689-B3F6-F8E2D84931BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x950d4000 - 0x950d4fff com.apple.Carbon (154 - 157) <33457512-4EA2-373B-BB04-A6A7B6D4E54A> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x950d5000 - 0x950e0fff com.apple.CrashReporterSupport (10.9 - 538) <16850C12-BBC7-3F02-AA33-A0BFE5FAD6FE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x950e1000 - 0x950e6ff3 libsystem_platform.dylib (24.1.4) <03238EB4-2C7C-3D55-8FA4-12F697B88878> /usr/lib/system/libsystem_platform.dylib
0x950e7000 - 0x9515afff com.apple.SearchKit (1.4.0 - 1.4.0) <B07169DD-5577-3898-8146-0E63A5FD31DF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9515b000 - 0x9515dff2 com.apple.EFILogin (2.0 - 2) <A884A315-7857-3BF8-97FA-1EB4A61C97F8> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x9515e000 - 0x95ff7ff9 com.apple.WebCore (9537 - 9537.70) <353B35B3-E323-3708-85CE-EF87AC58C2A8> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x95ff8000 - 0x96002ff7 com.apple.speech.synthesis.framework (4.6.2 - 4.6.2) <16E20DCD-89F4-3C8E-9DBA-EED359807038> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x96003000 - 0x9609aff7 com.apple.ink.framework (10.9 - 207) <710EF47E-89F1-317F-AEAB-A42FE0E40B92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x960a6000 - 0x960a9ffb libutil.dylib (34) <B496031E-E763-3DEB-84D2-85C0F3DF2012> /usr/lib/libutil.dylib
0x960aa000 - 0x960acffe com.apple.QuickTimeH264.component (7.7.3 - 2826) <0687F46E-FF70-3030-B02C-A1588D9FEAE7> /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x960ad000 - 0x960dcfff com.apple.framework.SystemAdministration (1.0 - 1.0) <B3E7E274-86D7-3AFC-9FA4-0B01D3EB152E> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x960dd000 - 0x960e9ffc libbz2.1.0.dylib (29) <3CEF1E92-BA42-3F8A-8E8D-9E1F7658E5C7> /usr/lib/libbz2.1.0.dylib
0x960ea000 - 0x964e2ffe com.apple.CoreGraphics (1.600.0 - 599.7) <A98A8C69-9394-301F-9504-0728EFFC9854> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x964e3000 - 0x964f6fff com.apple.ImageCapture (9.0 - 9.0) <2128121D-9069-3BF2-BE7D-D6CD7B9C6630> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x964f7000 - 0x964f8ffa libsystem_sandbox.dylib (278.10) <31C77DCA-F6CA-33F7-BE57-500932EA8494> /usr/lib/system/libsystem_sandbox.dylib
0x964f9000 - 0x964fdfff com.apple.CommonPanels (1.2.6 - 96) <CDB85D69-FF93-31CF-B530-5DA366C9288C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x964fe000 - 0x96544ff7 libFontRegistry.dylib (127) <BB1B8711-BEC9-3D0B-8C8D-9697039EE033> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x96545000 - 0x9659afff libc++.1.dylib (120) <AE695E83-E3C6-3F13-BFC2-A2945AEAB0AC> /usr/lib/libc++.1.dylib
0x9659b000 - 0x965a8ff7 com.apple.HelpData (2.1.4 - 90) <E61ECE08-7594-3E65-B629-0ED855ABCC00> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x965a9000 - 0x965afffc libCGXCoreImage.A.dylib (599.7) <DD6EC661-E44C-395E-AB11-3226B4964AC7> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x965b0000 - 0x96a57fe7 com.apple.CoreAUC (6.22.08 - 6.22.08) <D3D4EF49-FEC9-3B40-A0BD-BBCDF638410E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x96a58000 - 0x96aa6ff9 com.apple.HIServices (1.22 - 466) <30636237-408A-3552-90C1-1279348DF7CB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x96aa7000 - 0x96abffff com.apple.CFOpenDirectory (10.9 - 173.1.1) <630A5CCF-8FC3-379D-B0BD-41DCE1F0B624> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x96ac0000 - 0x96ac4fff libheimdal-asn1.dylib (323.12) <9EA2A221-301B-3B9A-BBF2-38134145B5A8> /usr/lib/libheimdal-asn1.dylib
0x96ac5000 - 0x96ac6ffc com.apple.TrustEvaluationAgent (2.0 - 25) <064B485D-56E0-3DD7-BBE2-E08A5BFFF8B3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x96ac7000 - 0x96acaff7 com.apple.help (1.3.3 - 46) <616B1C40-AAB2-3041-9CBE-A7058E4285B5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x96acb000 - 0x96aceff3 com.apple.AppleSystemInfo (3.0 - 3.0) <4586B503-A0A8-3654-AA48-D2F9FA0188CB> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x96acf000 - 0x96afdff3 com.apple.DebugSymbols (106 - 106) <37B107F9-4AA0-39FF-9602-A27811C8DC96> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x96afe000 - 0x96b0eff7 libsasl2.2.dylib (170) <CA1C07F6-8E17-315E-AE49-AB696DDE6707> /usr/lib/libsasl2.2.dylib
0x96b0f000 - 0x96b70ff7 com.apple.Symbolication (1.4 - 129) <E5948C08-6ADF-3D86-9134-6AE49CF1DA0F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x96b71000 - 0x96b71ffd com.apple.audio.units.AudioUnit (1.9 - 1.9) <F43CF0ED-A017-35EE-813D-37D08A60A74B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x96b72000 - 0x96b9dff7 libpcap.A.dylib (42) <66FBEAD3-FE91-3A89-8706-FB95229068AC> /usr/lib/libpcap.A.dylib
0x96b9e000 - 0x96bb7fff com.apple.Kerberos (3.0 - 1) <B5231442-5643-3605-8464-8F654A4C5019> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x96bb9000 - 0x96bbeff7 com.apple.print.framework.Print (9.0 - 260) <6875EC0C-7DD0-3660-AFD6-25E407F49E0D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x96bbf000 - 0x96be7ff7 libRIP.A.dylib (599.7) <B109DD2D-A235-3C4C-B67C-E83F1B4E57A1> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x96be8000 - 0x96beafff libquarantine.dylib (71) <39FC7A3E-9508-3C82-9945-4E4229742FEC> /usr/lib/system/libquarantine.dylib
0x96beb000 - 0x96c0ffff libxpc.dylib (300.1.17) <9115C2E7-FA58-3D25-8676-6360C7CF8E13> /usr/lib/system/libxpc.dylib
0x96c10000 - 0x96c6eff7 com.apple.CoreUtils (1.9 - 190.4) <8F169D88-9D9A-3D12-8C8F-287CC7F286C7> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x96c6f000 - 0x96c93fff libJPEG.dylib (1038) <1154DC9B-6E0C-3EED-9C39-E382474B5FC1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x96c94000 - 0x96cacff7 libsystem_malloc.dylib (23.1.10) <689AB95D-FF71-364E-B6C7-7EFD1E4CB7E6> /usr/lib/system/libsystem_malloc.dylib
0x975d4000 - 0x975d4fff com.apple.Accelerate (1.9 - Accelerate 1.9) <E8443BE8-482C-300A-BEDA-EDB07242A64B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x975d5000 - 0x9772bff0 libBLAS.dylib (1094.5) <5A53FE27-32DE-322C-BAB3-E03B93D37F88> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9772c000 - 0x9777cff7 libcorecrypto.dylib (161.1) <135FD99E-2211-3DF4-825C-C9F816107F0C> /usr/lib/system/libcorecrypto.dylib
0x9777d000 - 0x9777fffb libRadiance.dylib (1038) <B3B8CD5D-74C8-3D73-BC98-21F7B18E77C1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x97780000 - 0x977abff7 libsystem_network.dylib (241.3) <FA1F2F7B-93B9-37FD-8070-A60725749A1F> /usr/lib/system/libsystem_network.dylib
0x977ac000 - 0x977c1ff3 com.apple.AppContainer (3.0 - 1) <84FB395F-0467-3D21-8FB5-4ED7BB9C82E7> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x977c2000 - 0x977cffff com.apple.Librarian (1.2 - 1) <AA456CBE-F102-3FC5-8980-E4C0ED6DEA3B> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x977d0000 - 0x977d0fff libkeymgr.dylib (28) <43297D93-111A-3880-AE0D-55C7404C52DC> /usr/lib/system/libkeymgr.dylib
0x977d1000 - 0x97933ff3 com.apple.CFNetwork (673.0.3 - 673.0.3) <5E0E9AE8-073B-3F2B-B0C7-A0129DE787F6> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x97934000 - 0x97937ff9 com.apple.TCC (1.0 - 1) <DE9FBF11-4ABB-317F-A3F8-4D26A98A5AEF> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x97938000 - 0x9793effb libunwind.dylib (35.3) <316039E0-FB7A-35DA-89BE-C461213D6BDE> /usr/lib/system/libunwind.dylib
0x9793f000 - 0x979dbfff com.apple.QD (3.50 - 298) <39109A21-3337-3F6D-B33B-53737C2187E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x979dc000 - 0x979f8fff libCRFSuite.dylib (34) <FFF76EBA-DF35-3A5F-857F-3F4B1C9F4C77> /usr/lib/libCRFSuite.dylib
0x979f9000 - 0x97a4eff7 com.apple.framework.internetaccounts (2.1 - 210) <59D25184-8230-332C-9083-BCE231C09C0D> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
0x97a4f000 - 0x97a72ff7 libc++abi.dylib (48) <5367BE5A-D475-3FB4-972D-E1DC999A709A> /usr/lib/libc++abi.dylib
0x97a73000 - 0x97ae8ffb com.apple.framework.IOKit (2.0.1 - 907.1.13) <86D72735-9DFB-35C8-83F7-CE0DCF17D354> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x97ae9000 - 0x982a9ffd libclh.dylib (4.0.3 - 4.0.3) <ECC72D1C-9345-3195-8A8C-591F170DD86B> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x982aa000 - 0x982dfffd libssl.0.9.8.dylib (50) <F3BEA2DF-DB84-37F0-B4C7-97C0A4DF19C9> /usr/lib/libssl.0.9.8.dylib
0x982e0000 - 0x982e4ffa libcache.dylib (62) <F69AA956-EA55-3562-8A8E-C6393662B1D6> /usr/lib/system/libcache.dylib
0x982e5000 - 0x98341ffa com.apple.print.framework.PrintCore (9.0 - 428) <68C13032-D1B7-31C7-968B-E4C6325A0DA7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x98342000 - 0x98345fff libdyld.dylib (239.3) <ED3D413D-D8FE-39A3-ADF4-00B4E7244A67> /usr/lib/system/libdyld.dylib
0x98346000 - 0x98421ff7 com.apple.LaunchServices (572.23 - 572.23) <7E52FB5C-9ECF-3CB9-BF18-6652B8D8CDE0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x98422000 - 0x984a7ffc com.apple.CorePDF (4.0 - 4) <4E3E1736-36AD-3B1C-BEFF-45F5B92D2745> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x984a8000 - 0x98553ffd com.apple.imcore (10.0 - 1000) <325331F3-98B9-336E-B17C-C2E958265F08> /System/Library/PrivateFrameworks/IMCore.framework/Versions/A/IMCore
0x98554000 - 0x987d2ff7 com.apple.imageKit (2.5 - 770) <A9FDD29A-55C7-35BE-A561-91034C7D189B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x987d3000 - 0x98bf8fe3 com.apple.VideoToolbox (1.0 - 1273.35) <053E5F1E-54F4-3EA9-B421-5F5D114F8E7F> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x98bf9000 - 0x98c03ff0 libCGInterfaces.dylib (271) <4CB76EE7-456B-3A2A-A66E-C341ED30A788> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Resources/libCGInterfaces.dylib
0x98c04000 - 0x98ca2ff7 com.apple.PDFKit (2.9 - 2.9) <37688132-FF6B-3A62-A7BA-6C5E0CCEC738> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x98ca3000 - 0x98ca8ff6 libcompiler_rt.dylib (35) <B838D63E-59DD-3C07-A17F-F90906F3FB09> /usr/lib/system/libcompiler_rt.dylib
0x98ca9000 - 0x98faaff1 com.apple.AOSKit (1.06 - 176) <D2467816-0871-3CED-A1E2-A418EDEF25AE> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
0x98fab000 - 0x98fc2ff4 com.apple.CoreMediaAuthoring (2.2 - 947) <DE5E1DB2-F8CB-3132-A1A9-6F50BDD0A559> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x99064000 - 0x990f6ffe libsystem_c.dylib (997.1.1) <8288A730-B230-34E2-8C4B-6A1FBD12C023> /usr/lib/system/libsystem_c.dylib
0x990f7000 - 0x990ffffe libGFXShared.dylib (9.3.1) <1EF75B97-012E-3730-8017-5E832946B83D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x99114000 - 0x99120ffe libkxld.dylib (2422.75.4) <E33644D0-8809-356F-8144-67CC09052E9B> /usr/lib/system/libkxld.dylib
0x99121000 - 0x99122fff liblangid.dylib (117) <F18F76C6-7E4B-34AD-AE81-C1C031BF2F7D> /usr/lib/liblangid.dylib
0x99123000 - 0x9916bfff com.apple.PerformanceAnalysis (1.47 - 47) <48BE84A9-3753-3CDA-A092-2F8CA36C731C> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x9916c000 - 0x9926afff libJP2.dylib (1038) <E5860548-4C4F-3C4D-948E-1A25EF5ADA71> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x9926b000 - 0x99274fff com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <E2A5F1E3-2B8A-3E85-8559-18B1A29AE271> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x99275000 - 0x9927dfff libcopyfile.dylib (103) <3442BBA3-ABB7-3A7D-9F8A-DB55A3CA2151> /usr/lib/system/libcopyfile.dylib
0x9927e000 - 0x992f4ff3 com.apple.securityfoundation (6.0 - 55122) <25149798-A37E-316F-84AB-93029EAF33D8> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x992f5000 - 0x99f10ff3 com.apple.AppKit (6.9 - 1265) <AE258D94-0272-394F-BBB7-9B5C165A4A78> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x99f11000 - 0x9a001ffb libiconv.2.dylib (41) <848FEBA7-2E3E-3ECB-BD59-007F32468787> /usr/lib/libiconv.2.dylib
0x9a002000 - 0x9a008ff7 com.apple.AddressBook.ContactsFoundation (8.0 - 1365) <74214669-BF64-3BC7-AC84-3BC7982FD4F1> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x9a009000 - 0x9a00dffc libpam.2.dylib (20) <763AC655-931B-3891-AB6A-F2CD4A21F906> /usr/lib/libpam.2.dylib
0x9a00e000 - 0x9a046ff7 com.apple.MediaKit (15 - 709) <9B0484C2-953C-34EB-BFAB-1190F55BB632> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A
Re: OS X Mavericks
Posted: Sun Jan 05, 2014 4:24 pm
by Cody
Fletch wrote:Before changing OS, It could be that you are running out of RAM. Have you tried watching the RAM usage before-during-after the "crash"? Have you tried rendering on Easy 09 render setting? It should take less RAM than Easy1-7 render settings.
Fletch, I don't think ram is the problem. I have a 6 gb ram iMac and a 16 gb ram macbook pro. The macbook pro is the one that keeps crashing and it has the new mavericks system, where I am using Lion on my 6 gb machine and it doesn't crash. Same model and export settings too.
Don't know if that helps any.
